hey guys,
thinking of upgrading my 4spd to a 5spd gearbox, just wondering what are my options, im not making too much hp, nore am i gonna to thrash it (much) im interested in the celica boxes on ebay, or if someone has one here? or something else? dont wanna pay too much.
my questions are, what mods need to be made to accomondate for this gearbox, it will be behind a 186 engine. just the bellhousing and speedo cable?
Need any clutch mods?
Cheers. appriciate as much info as possible.
![](https://secure.gravatar.com/avatar/d41d8cd98f00b204e9800998ecf8427e?s=100&d=https%3A%2F%2Fwww.gmh-torana.com.au%2Fforums%2Fpublic%2Fstyle_images%2Fblackstream%2Fprofile%2Fdefault_large.png)
Converting to a Celica 5spd
_hrt1and2_
, Jul 04 2006 05:58 PM
7 replies to this topic
_hrt1and2_
Posted 04 July 2006 - 05:58 PM
_munro_
Posted 04 July 2006 - 06:12 PM
bellhousing, clutch plate ,spigot bush, speedo cable ,cross member tailshaft and yoke all need changing/modification.
if your running an Lc or Lj you'll also need a forward shift to clear the handbrake.
this is a common conversion and company's like dellow and crs do kits for these.
or hunt around and get a 2nd hand one
tom
![:spoton:](http://www.gmh-torana.com.au/forums/public/style_emoticons/default/spoton.gif)
_troy_
Posted 06 July 2006 - 12:43 AM
Currently doin the conversion
Dellow bellhousing,crossmember,$100
Registered 1978 Celica $250 ,got the clutch,speedo cable,Gearbox
Tailshaft modification $150 Spigot bush $15
Jobs done, Best move i ever made
_hrt1and2_
Posted 06 July 2006 - 12:04 PM
hmmm not too bad. ebay did have some cheap celica boxes with the holden bellhousing attatched.
_Sammy_
Posted 06 July 2006 - 03:35 PM
ok here my 2 cents worth.
in an lh/lx/uc, you can use lc/lj tailshaft .... that sorts that out.
hydraulic clutch, heavy as, wears out the master cylinder fairly quick too ....
if you have the mouse trap setup you'll problably be right, otherwise i suggest getting a cable bellhousing for the celica box.
lh/lx/uc you need a modified crossmember, this is a trimatic/aussie 4 speed one modified (i dunno if any other ones are made)
![Posted Image](http://www.oldholdens.com/images/cars/bluelhtorana/freshenup/oldmotor/celicacrossmember1.jpg)
![Posted Image](http://www.oldholdens.com/images/cars/bluelhtorana/freshenup/oldmotor/celicacrossmember2.jpg)
![Posted Image](http://www.oldholdens.com/images/cars/bluelhtorana/freshenup/oldmotor/celicacrossmember3.jpg)
and just for good measure, my celica box with dellow bellhousing - its the one with the 3.28 first gear, i think you can also get 3.50 first gear, maybe thats just supra, either way, 3.50 is #@$^%&!!! avoid it!
![Posted Image](http://www.oldholdens.com/images/cars/bluelhtorana/freshenup/oldmotor/celica5speed1.jpg)
_troy_
Posted 10 July 2006 - 11:59 PM
My convesion is complete with 1978 steel case the only headache was the exhaust system mods but layin down the rubber road to freedom now!The difference between the aussie 4spd and the celica is like drivin a sigma vs bmw
_hrt1and2_
Posted 11 July 2006 - 12:49 PM
isn't a aussie 4 speed stronger than a 5 speed celica?
_munro_
Posted 11 July 2006 - 01:54 PM
no where near the toyota boxes are heaps strongerisn't a aussie 4 speed stronger than a 5 speed celica?
