Holley Hp 125
16 replies to this topic
#1 _LX355SLR_
_LX355SLR_
Posted 02 January 2014 - 09:27 AM
Hi Guys,
Last week i invested in a holley HP 125 to quieten down the ridiculously loud fuel pump. Went in fine and can barely hear it but i only got 2kms down the road and the motor run dry of fuel. The fuel pump was still buzzing away but no pressure at the motor. Waited a few minutes and it just re-gained pressure. I ended up removing the reg and blowing the line out and still had the issue but not as frequent and seems only when i put my foot down. When the problem happens i remove the feed line to motor from the fuel pump and after a half a second delay, it starts pumping again. Filled the tank right up and it seemed to be working fine until yesterday after driving slowly up a steep hill it cut our again. The bloke From Chris Mills is thinking it could be gravity feed issue but its in the same spot as the existing pump which never had this issue, i am thinking maybe its backing up some how to 7psi and stops pumping as thats the cut off for these pump.
Any Suggestions, Cheers
Edited by LX355SLR, 02 January 2014 - 09:28 AM.
#2 _mumbo_
_mumbo_
Posted 03 January 2014 - 07:30 AM
I use the HP150 in mine and it sits below the tank but it still won't self prime , I would say it's something before the pump causing you problems
#3 _oldjohnno_
_oldjohnno_
Posted 03 January 2014 - 10:40 AM
If only there was some sort of pump that didn't make any noise, was reliable, didn't need a power supply (powered by the engine perhaps?) and would tolerate the occasional gulp of air without dropping its bundle...
One day maybe, but until then we can only dream...
#4 Litre8
Litre8
    Thrillseeker
  • 2,399 posts
  • Name:Howard
  • Car:1976 LX SLR8000
Posted 03 January 2014 - 11:00 AM
#5 _mumbo_
_mumbo_
Posted 03 January 2014 - 12:17 PM
My HP150 has been on the car for 7 years it doesnt make any noise
#6 warrenm
warrenm
  • 2,130 posts
  • Car:1972 LJ Torana
Posted 04 January 2014 - 09:47 AM
What if someone was able to invent a mechanical means of pumping. :stirpot:
#7 _oldjohnno_
_oldjohnno_
Posted 04 January 2014 - 10:04 AM
But that's the stuff of science fiction, surely?
Seriously, we are our own worst enemy sometimes in our inability to resist shiny, billet anodised bits that really don't do anything worthwhile. How many threads have been posted here asking how to fix problems with an electric fuel pump/gilmer drive/electric water pump/MSD/chrome rocker box? These trinkets seem to cause way more problems than they solve.
#8 warrenm
warrenm
  • 2,130 posts
Posted 04 January 2014 - 02:35 PM
Agree.^
If I didn't get a noisy Holley Black at the right price, I would still be using a mechanical pump.
#9 _mumbo_
_mumbo_
Posted 05 January 2014 - 11:05 AM
Unfortunately there's not to many mechanical fuel pumps that will keep up with a 10 sec street car same goes for standard ignition systems .
I find most problems with all this unreliable performance parts is more often user error
#10 _oldjohnno_
_oldjohnno_
Posted 05 January 2014 - 03:58 PM
Oh puhlease.. there are easily available mech pumps that'll do 200gph, and I don't consider an N/A drag car to have a particularly taxing ignition requirement either. Half a century ago people were running 10s with mech pumps and points n' coil...
#11 _mumbo_
_mumbo_
Posted 06 January 2014 - 07:26 AM
What ever
#12 warrenm
warrenm
  • 2,130 posts
Posted 07 January 2014 - 06:18 AM
http://www.racepumps.com/index.html
#13 _LX355SLR_
_LX355SLR_
Posted 07 January 2014 - 08:31 AM
Thanks Mumbo, what filter do you run. I have heard these pump can be picky with the filters. Happened to me 3 times last time I took it out and seems to be more prominent when the tank has low fuel in it.
#14 _mumbo_
_mumbo_
Posted 08 January 2014 - 07:32 AM
I use a 5" long Aeroflow 60 micron filter , it's big and free flowing
#15 _LX355SLR_
_LX355SLR_
Posted 10 January 2014 - 08:45 PM
And do you run it before or after the pump
#16 _mumbo_
_mumbo_
Posted 11 January 2014 - 08:15 AM
Before , the hard part is mounting the pump low enough if your running a standard tank it's not easy but the lower the better
#17 _202Corona_
_202Corona_
Posted 14 January 2014 - 08:48 AM
But we like shiny things............I fell for the lure of a shiny thing once. Lasted 5mins of ill fitting before i chucked it
