LH - LX Bolt Identification
8 replies to this topic
#1 notna
notna
  • 706 posts
  • Name:Reverse of username
  • Car:1976 LX L32 SL/R
Posted 06 January 2014 - 11:28 AM
G'day all.
Looking for some help in identifying where the following bolts were used. Over the years, I have stripped LH/LX and UC Toranas, and recently I cleaned up a collection of panel / door bolts and had them plated.
Now I am reassembling my LX SL/R, and want to use the appropriate bolts in the correct location. Only problem is, I can't remember if there is a particular place for certain bolts.
I seem to have 5 types of bolt with the same thread, and differing bolt heads.
PIC #1:
1. Bonnet hinge bolts - all good
2. Recessed head with flat washer only
3. Recessed head with spring washer only
4. Flat head with spring washer only
Attached File  1479273_10152165494607491_547691087_n.jpg   110.33K   8 downloads
PIC #2:
ALL. Recessed head with flat washer only, the underside of which has a serrated type of edge face.
Attached File  1374822_10152172633687491_1758009164_n.jpg   126.99K   5 downloads
Can anyone confirm if Holden used these certain bolts in specific places? Or was it a little bit random?
Cheers!
#2 Statler
  • 6,328 posts
Posted 06 January 2014 - 12:08 PM
2/: guard bolts, panel bolts.
3/: door hinges.
4/: dont remember.
#3 BIG KEV
BIG KEV
  • 1,218 posts
  • Name:Kevin
Posted 06 January 2014 - 04:55 PM
I would agree with the above .....
1 ....Bonnet hinge bolts
2.....Guard bolts
3.....Door hinge bolts
4.....boot lock and bonnet catch bolts
I hope this helps
#4 notna
notna
  • 706 posts
Posted 08 January 2014 - 11:43 AM
Cheers guys for the follow-up. This and some inbox info has helped greatly.
#5 SmacT
SmacT
  • 1,003 posts
  • Name:Sam
  • Car:LX 4dr 383, TKX, BW
Posted 18 August 2014 - 10:59 PM
Hi Notna,
Old thread, but any chance of throwing up your inbox info as we'll? The bolts as I removed them don't match the legend above. My flat head bolts with spring washers were in my door hinges for instance.
Any more info would be great, as I need to get them zinced soon. Also, can anyone recommend a good zincer? I am in the Hornsby area.
#6 tuxedoss
tuxedoss
  • 1,027 posts
  • Car:ss
Posted 19 August 2014 - 03:23 PM
The door bolt recessed and flat head question was talked about before. Maybe try a search but it may have been the door bolts were different to the bolts on the body.
#7 _The Baron_
_The Baron_
Posted 19 August 2014 - 06:03 PM
If I recall correctly,
Door hinge to Body = flat head with washer (bolt 4 from the left)
Door hinge to Door = crowned head with washer (bolt 3 from the left)
Picture 2 = seat bolts
#8 SmacT
SmacT
  • 1,003 posts
  • Name:Sam
Posted 19 August 2014 - 06:58 PM
Thanks guys. My flat heads (#4) were hinges to the door, but it has been painted before by somebody else so, buggered if I know if that's right.
I will search more.
#9 tuxedoss
tuxedoss
  • 1,027 posts
  • Car:ss
Posted 21 August 2014 - 10:34 AM
So has anyone worked out why the different head style for the hinge bolts? The bolts seem identical apart from the shape of the head.
