Stoneguard Fry-up...
9 replies to this topic
#1 _Lazarus_
_Lazarus_
Posted 13 January 2014 - 05:53 PM
Has anyone had problems with Septone aerosol Stone Shield frying up ?
I'm trying to paint the bottom of my fuel tank with it and got a major fry-up in a couple of places. Plenty of primer on first but I didn't use Wax and Grease remover mainly because I had the same problem on something else a couple of weeks ago with a different primer, same story, only in a couple of spots, and that time I went over the primer with Wax and Grease Remover.
Is the Septone product sh!t and should I try something else, should I use a certain primer (on the can it just says something like 'appropriate primer', or is there some trick to using this sh!t.
I have never used it before. Usualy I use brush on Sound Deadener but I thought I would go for the smooth look on the tank this time.
Thanks.
#2 _Bomber Watson_
Posted 13 January 2014 - 06:32 PM
Never used the aerosols before, are they water or solvent based?
#3 _Lazarus_
_Lazarus_
Posted 13 January 2014 - 07:13 PM
This one is solvent based.
#4 _Bomber Watson_
Posted 13 January 2014 - 07:20 PM
WHat kinda primer?
#5 _Lazarus_
_Lazarus_
Posted 13 January 2014 - 07:50 PM
This time it was aerosol Rust-Oleum.
Last time it was SLCS or whatever it is etch primer out of a gun.
I was thinking I'll sand the affected areas (only maybe 5% of the bottom of the tank), primer again and then put a topcoat down before I try there again ?
#6 _Bomber Watson_
Posted 13 January 2014 - 08:12 PM
Interesting.
Isnt Rust Oleum like furniture paint or something?
I would be more inclined to try a primer that is definitely compatible, depending on what you can get locally, perhaps even Septone 1k etch in a pressure pack?
#7 _Lazarus_
_Lazarus_
Posted 13 January 2014 - 08:19 PM
Rust-Oleum make metal paint also, hence the name.
Bunnings sell it, it's cheap too, like $10 a can. But many people say it is good quality.
Here DJ, you'll love this -
http://www.youtube.c...h?v=_qPJTTRWttQ
#8 _Bomber Watson_
Posted 13 January 2014 - 08:27 PM
Hmmm. I stick to my previous comment.
#9 _Lazarus_
_Lazarus_
Posted 13 January 2014 - 09:11 PM
Thanks mate, I'll see if I can get some down the road here or get some in Bundy next time I go.
I've got some acrylic black Septone in a spraypac I bought for guide coat. That's why I was thinking I could try a topcoat first. I might give it a little try tomorrow just for the hell of it..
#10 _Bomber Watson_
Posted 13 January 2014 - 09:18 PM
Yeah give that a go, see what happens.
I rarely use pressure packs except for little brackets and stuff i make up for the dungers, so this is all a bit out of my knowledge base.
