Dissy gear
10 replies to this topic
#1 gad05
gad05
  • 421 posts
  • Name:Graham
  • Car:73 lj 2 door , 74 lj sedan.
Posted 24 January 2014 - 09:53 PM
Hi all,
What gear are people using in their electronic dissy,holden six,steel or plastic?
Cheers Graham .
#2 S pack
  • 15,747 posts
Posted 24 January 2014 - 10:01 PM
I don't run a HEI dizzy, however, there is only one thing to do with a nylon gear and that is give it a new home in a rubbish bin.
#3 N/A-PWR
  • 9,644 posts
Posted 24 January 2014 - 10:41 PM
Hi Graham,
Got a steel one on now as the two nylon ones that were on lost a couple of teeth each and you go no where hey. Dave I
p.s. I think you can use bronze one's too
#4 warrenm
warrenm
  • 2,130 posts
  • Car:1972 LJ Torana
Posted 25 January 2014 - 06:30 AM
Steel, the same as is fitted on the oil pump.
#5 _Ned Loh_
_Ned Loh_
Posted 25 January 2014 - 07:17 AM
I use a NEW nylon gear. Helps minimise spark scatter. Don't re-use a 30 year old nylon gear...just asking for trouble.
#6 gad05
gad05
  • 421 posts
  • Name:Graham
Posted 25 January 2014 - 10:39 AM
Thanks for the feedback guys.
Where can you buy steel or nylon gears?
Cheers Graham.
#7 N/A-PWR
  • 9,644 posts
Posted 25 January 2014 - 11:31 AM
http://www.ebay.com....db42e17b&_uhb=1
http://www.ebay.com....6f375782&_uhb=1
#8 S pack
  • 15,747 posts
Posted 25 January 2014 - 11:53 AM
GMH trialled the Nylon gears in the early 70's and eventually found they were more prone to spark scatter (as you call it) plus other problems than the steel gears.
#9 _Ned Loh_
_Ned Loh_
Posted 25 January 2014 - 01:00 PM
Nah, the nylon acts as a damper. Only a marginal difference mind you, and scatter can still be present.
Also - Fairly sure most of the original Bosch HEI (so early 80's) I have pulled out had a plastic gear fitted.
#10 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 25 January 2014 - 08:22 PM
+1
Where can i get a new Nylon gear Ned?
or is it just when they pop up on ebay?
#11 _Ned Loh_
_Ned Loh_
Posted 28 January 2014 - 08:47 AM
+1
It's a few years since I got the last one, but in the past I've picked them up from Performance Ignition Services in Nunawading.
You would have to be able to buy them cheaper from a parts place, but to be honest I've never tried to buy them elsewhere.  I find the advice I get when picking up the gear well worth it.  Makes the price of the gear cheap even...
