lj fine spine axles
8 replies to this topic
#1 _datpsi_
_datpsi_
Posted 05 February 2014 - 09:36 AM
Got an lsd banjo outta god knows what and needing some fine spine axles to suit an lj. Did some ljs come out with these or needing modify to fit? cheers
#2 jd lj
jd lj
  • 2,118 posts
  • Name:James D
  • Car:LJ
Posted 05 February 2014 - 11:24 AM
These were fitted standard to the 73 Bathurst model Xu1's but will be hard to find any these days. However you must be able to get them made as my car has a fine spline lsd banjo, but when I had it rebuilt the diff guy told me they weren't oringal axles.
JD
#3 darway43
darway43
  • 215 posts
  • Name:David
  • Car:LJ 2 door
Posted 05 February 2014 - 11:48 AM
I have heard that Chrysler Centura axles also fit and are super strong. These also seem to be very difficult to find. I think some Group Nc guys use them.
Not sure if anyone can verify this but i would be keen to know as I am in the slow process of converting my LJ to a track car and want to keep it to Nc specs.
Dave
#4 S pack
  • 15,731 posts
Posted 05 February 2014 - 12:39 PM
Gemini 28 spline axles. Read Dr Terry's post #11
http://www.gmh-toran...3-bathurst-xu1/
#5 darway43
darway43
  • 215 posts
  • Name:David
  • Car:LJ 2 door
Posted 05 February 2014 - 06:39 PM
Champion! Thanks Dave.
My bro has a Gemini Wagon tucked away for when he has time/money to restore. Looks like it will be missing some axles when he next checks on it. Haha
Dave
#6 S pack
  • 15,731 posts
Posted 05 February 2014 - 07:21 PM
No wucking furries Dave.
Haha, just realised I wrote 28 spline instead of 23 spline. Should put my glasses on hey.
#7 dattoman
  • 16,487 posts
Posted 05 February 2014 - 08:11 PM
Still going to be the wrong stud pattern though
#8 S pack
  • 15,731 posts
Posted 05 February 2014 - 08:41 PM
Post #10 from the linked thread.
warrenm said
The Gemini axle can have the stud holes welded, then re drilled to suit the Torana stud pattern, fit a Torana bearing. From memory I think a spacer is required behind the brake backing as the Gem axle is a couple of mm longer from the bearing to the flange, it's been a long time since I removed the banjo diff. The axle's from the station wagon are the better ones.
#9 _datpsi_
_datpsi_
Posted 06 February 2014 - 05:11 PM
Is there also anyone in WA to machine some billet ones?
