Holden 6 camshaft Waggott 409 - info ?
_torana_49_
Posted 05 February 2014 - 09:39 PM
I have an old cam that I got given a couple years ago, was only run in and did 2 laps around a race trAck until the eng lost oil pressure and spun a bearing.
I have the spec sheet, it says it's a Waggott 409 cam, (going off some googling) 217 - 217 @ 0.50" I believe?
What rev range would this cam be
And is it suitable for all old holden sixes ?
After some googling there's only some people that have put the cam in a 186.
Also says on the spec sheet :
Cam lift: 283"
Machine rocker pedestals: .080"
Guessing the pedestals have to be machined for this cam also?
Just trying to chase some more info on it to see if
It's even worth looking into for a 202 I'm building for a circuit car.
Cheers -
Posted 05 February 2014 - 09:57 PM
Hi Michael,
I say it is a small cam with a low rev range, and here is a Vid:-
Posted 05 February 2014 - 11:00 PM
Have a look at the CT35 517 the 4th one down, it could be similar, it is a very mild cam if your going to do a bit of track work.
http://www.camtechca...149202_hyd.html
_torana_49_
Posted 17 February 2014 - 03:20 PM
Would I have any problems putting this cam in a 202? I heard it was a 186 cam but I thought 186 - 202 are compatable
Posted 17 February 2014 - 07:04 PM
can go in both, cam will start working earlier in the 202 rpm. Dave I
Posted 17 February 2014 - 08:00 PM
Thats even to small for street use.
_threeblindmice_
Posted 20 February 2014 - 06:59 PM
_Phantom10_
Posted 27 March 2014 - 09:07 PM
Wow that video was from when I first built my 186.. that was a while ago
Posted 27 March 2014 - 09:47 PM
Good Man Ben,
Good to see who own's the Machine. Dave I
_stretchlc_
Posted 29 March 2014 - 12:25 PM
Waggott 409 cam specs
