Must do 202 mods
_VINESY_
Posted 19 February 2014 - 12:36 PM
Posted 20 February 2014 - 02:33 PM
Best exhaust you can afford is the first step. Has to breathe out before you can make it breathe in. Port match the extractors, make all exit joints smooth.
Check the brakes aren't binding, caliper kits are cheap and easy to do... and cheap insurance.
High compression head if it doesn't already have one, and good fuel and tuneup.
Onya for asking the 'experts'
_threeblindmice_
Posted 20 February 2014 - 03:33 PM
_VINESY_
Posted 21 February 2014 - 07:55 PM
Cheers lads. I had thought about the high comp head and a mild cam.
What is involved with match porting? I take it you would need to give the head to a machinist?
_Muzzy_
Posted 21 February 2014 - 08:49 PM
_VINESY_
Posted 21 February 2014 - 09:52 PM
Why did you go to a blue head Muzzy?
_Muzzy_
Posted 23 December 2014 - 05:20 PM
12 port way better flow than std red head and way cheaper than yella terra, the
Valves are bigger by 3 mm ex 4 mm inlet
Posted 23 December 2014 - 10:36 PM
