Ignition system 186
13 replies to this topic
#1 _glennhailstone_
_glennhailstone_
Posted 21 February 2014 - 07:24 PM
Hi all, whats a good dizzy to use with my 186 which I am rebuilding. Obviously I am looking for performance.
I have read the oldjohno stuff, and while it is good, I was wondering if somebody can simplify it a bit for me. At the moment I am thinking you don't need a separate coil with some of these, and some don't have points. Is there a good dizzy out there which I can just throw in. There are some on ebay:
HOLDEN Electronic Distributor Complete Kit Coil & Leads 138 149 161 179 186 202
OUR DISTRIBUTOR IS A MUST FOR THOSE WISHING TO UPGRADE THE IGNITION SYSTEM FROM POINTS, OR THE POORLY DESIGNED ELECTRONIC IGNITION THAT HOLDEN CAME OUT WITH AROUND 1974. THIS IS A TWO WIRE DISTRIBUTOR. THIS DISTRIBUTOR WORKS IN ALL CABURATED RED, BLUE AND BLACK ENGINES
oldjohno mentions the "Delco HEI from an AMC Jeep 232-258ci six cylinder to the Holden engine."
Thanks,
Glenn
#2 N/A-PWR
  • 9,640 posts
Posted 21 February 2014 - 07:53 PM
Hi Glynn,
I have used the original Dizzy with heaps of Power - in my view, it is not the dizzy, high end ones, are for making maximum gain from every rpm, but you need a very high performance motor with everything done. Dave I
#3 N/A-PWR
  • 9,640 posts
Posted 21 February 2014 - 07:56 PM
Just the timing at Idle should be 17 BTDC with a good worked motor and low vacuum
#4 _Bomber Watson_
Posted 21 February 2014 - 07:59 PM
Either get a coil in cap HEI and mod to suit or rebuild a factory electric one.
Or if your weird like me persist with points dizzy's :P
You didnt actually link to the ebay? add you quoted, but it sounds very pro comp. Google pro comp and see what the reviews are like....
#5 _glennhailstone_
_glennhailstone_
Posted 21 February 2014 - 08:02 PM
http://www.ebay.com....984.m1438.l2649
#6 N/A-PWR
  • 9,640 posts
Posted 21 February 2014 - 08:08 PM
I remember the points Dizzy and a GT40 Coil always growing a Pyramid in the points, that was when the Power Disappeared, so a file and off we go again. Dave I
Also, I set the points with a Redhead Matchbox Box, as it was about 17 thou
#7 _Bomber Watson_
Posted 21 February 2014 - 08:10 PM
Ah, what a contradictory add.
I ran one of those boch ripoffs in my old boat and it was alright. Infact just looking at it i recon my new boat has that exact setup and it hasnt failed yet.
Not procomp, so not to bad, but a bit pricey for what you get.
WHen you say your looking for performance, how much are you looking for?
Cheers. .
Edited by Bomber Watson, 21 February 2014 - 08:12 PM.
#8 N/A-PWR
  • 9,640 posts
Posted 21 February 2014 - 08:13 PM
Settle Down, ha ha
#9 _glennhailstone_
_glennhailstone_
Posted 22 February 2014 - 04:58 AM
Haha, well Im trying to get as much power as I can afford. Lets say the engines fully worked, with 3 webers.
#10 _glennhailstone_
_glennhailstone_
Posted 23 February 2014 - 07:26 AM
Does anybody else have more information on the different dizzys and how they work. Like which ones need coils and which ones don't and why.
Thanks heaps,
#11 _nodster_
_nodster_
Posted 23 February 2014 - 07:53 AM
VH commodore HEI dissy 12v to the coil bypass the resistor wire if you only had points in the car before 1mm gap on plugs all good i have these on my 186 motors never missed a beat not expensive
#12 _cliffos_
_cliffos_
Posted 23 February 2014 - 05:54 PM
as robert just said,
I have a VH commodore dissy in my 202 with triples & is sweet as ..... just had it re graphed , doesn't miss a beat
#13 _Muzzy_
_Muzzy_
Posted 23 February 2014 - 07:54 PM
I brought the eBay knock off copy of the VC VH , bosch unit
I linked it up with a MEC 718 coil
Seems fine, engine runs sweet
I have heard he module is not as good as the bosch unit, the rest is fine
Edited by Muzzy, 23 February 2014 - 07:56 PM.
#14 WhaleOilBeefHooked
WhaleOilBeefHooked
  • 1,671 posts
  • Car:LJ GTR
Posted 23 February 2014 - 08:06 PM
For All Out Performance Can't Go Past a Magneto of the Vertex Kind, No Coil or battery needed and zero point bounce at 9500 rpm's which your lil 6 pack will never see, Can be had for $500+ and damn hard to beat......
