Vy commodore fuel economy
27 replies to this topic
#1 _JNR_ATE_
_JNR_ATE_
Posted 19 March 2014 - 08:54 PM
Hi guys. I know it's commodore but I can't post in street commodore forum yet.
I just got a 2004 VY one tonner, ecotec 6, auto
Fuel economy is BAD. 14.2ltr/100km.
300km to a tank.
They can't be that bad can they?
Suggestions please.
Thanks.
#2 dattoman
  • 16,488 posts
Posted 19 March 2014 - 09:05 PM
That is bad
#3 mitchg
mitchg
    The guy with the Torailer
  • 3,111 posts
  • Name:Mitch
Posted 19 March 2014 - 09:08 PM
O2 sensors. Even if a code isnt thrown, they can make it reallllyyy bad.
#4 r2160
r2160
  • 712 posts
  • Name:Glenn
  • Car:2/71 LC GTR, 4/71 LC 4 'S'
Posted 19 March 2014 - 09:23 PM
I had a VT that was playing up. Turned out that one valve spring had broken at half a turn, and not only did the car run like a pig, but used heaps of juice. Have you thought about buying the software and cable and checking the computer out to see if it tells you anything?
http://www.ebay.com....376f051e&_uhb=1
Glenn
#5 _JNR_ATE_
_JNR_ATE_
Posted 19 March 2014 - 09:36 PM
Runs fine. Starts fine, doesn't blow smoke. No codes, at Idle. 15.2l/100
#6 S pack
  • 15,740 posts
Posted 19 March 2014 - 09:38 PM
300km to a tank.
Suggestions please.
Thanks.
Haha, you think that's bad. My VZ 3.6L alloytec 4spd auto is worse. Average 16L per 100k's around town.
I'd be happier if mine was returning 14L per 100.
Edited by S pack, 19 March 2014 - 09:40 PM.
#7 rodomo
  • 18,050 posts
Posted 19 March 2014 - 09:48 PM
Are we going on actuals here or relying on the unreliable gizmo on the dash?
I have an 04 VY Crewman with the early engine and it says 10L/100
#8 _UCLX_
_UCLX_
Posted 19 March 2014 - 09:54 PM
I concur, check the O2 sensors.
My 2004 VY series 2 crewman 3.8 auto stock standard returns 11.5 litres per 100 klm average around town, and 9.5 to 10.0 out on the highway.
Am cheating just a little bit, I am using ULX-110 5W - 40 grade oil. This oil is super slippery.
Cheers,
Daryl.
#9 mitchg
mitchg
  • 3,111 posts
  • Name:Mitch
My high stall ls1 gets 300kms to a tank so something is wrong with yours.
O2 sensors, clean maf / air filter / throttle body. Busted cat?
As I said, I had no codes but used so much fuel (when it was stock), changed o2 sensors and fuel economy jumped by 100+kms
#10 _JNR_ATE_
_JNR_ATE_
Posted 19 March 2014 - 11:00 PM
Nope. 298km to the tank. Might of squeazed 330 maybe.
Will change out and let you boys know.
Thanks.
#11 _Macca97_
_Macca97_
Posted 20 March 2014 - 09:36 AM
thats bad, our big WH(VX/VY equvelent) stato with the 3.8 gets 8.6L per 100
Vz crewman with crappy 3.6 gets 10-11L oer 100
Defently something wrong with yours, maybe wear lighter shoes :P
#12 gad05
gad05
  • 421 posts
  • Name:Graham
  • Car:73 lj 2 door , 74 lj sedan.
Posted 20 March 2014 - 09:45 AM
My series 2 vy ute gets 9•8 ,9•9 l per 100.
Definitely a problem there.
Cheers Gad.
#13 _judgelj_
_judgelj_
Posted 20 March 2014 - 10:21 AM
My mates vz ss gets 4-450
#14 yel327
  • 13,714 posts
Posted 20 March 2014 - 10:22 AM
That is OK for a V8 auto but not for the budget engine. My V6 auto Hilux 4x4 averages 14 on E10 and I drive it hard!
#15 myss427
myss427
  • 1,636 posts
Posted 20 March 2014 - 10:37 AM
My LS1 Monaro gets 11's arround town (if driving sensible) so you got a problem there.
#16 _JNR_ATE_
_JNR_ATE_
Posted 20 March 2014 - 11:03 AM
Ok. 2 good second hand ones fitted. Trip gauge still reads 14.2/3 but will see what in get per tank. 160 to nearly half tank.
O2 sensors where very white.
#17 _outer control_
_outer control_
Posted 20 March 2014 - 01:20 PM
Some engines are frieks we had a vy spack auto that returned 800 to 850 kms between tank fills and that wasnt a trip. Told buyer and i dont think he believed me but rang 6 weeks later singing its praise (the cost of updating)
Edited by outer control, 20 March 2014 - 01:21 PM.
#18 _JNR_ATE_
_JNR_ATE_
Posted 20 March 2014 - 03:37 PM
#19 arrimar
arrimar
  • 3,134 posts
Posted 20 March 2014 - 03:54 PM
Our L34 used 682 litres (180gal.) on the trip to Phillip Island and back.
4,500kms @ 15.15L/100km.
2,796m@ 15.53mpg.
First 1,700kms were highway 107kmh @2,500rpm We were getting 17.3mpg.
#20 r2160
r2160
  • 712 posts
  • Name:Glenn
Posted 20 March 2014 - 04:28 PM
I would check the cat out as well. If they block or clog a little, the backpressure "kills" the engine.
A mate had a mitsu magna that used to get 200km from a tanki, after months, they found the cat had collapsed internally
Glenn
#21 _toranatime_
_toranatime_
Posted 20 March 2014 - 05:32 PM
my vy ute gets 9-10l/100km and up to 11's around town. could it be something related to your air intake? filter?
#22 _JNR_ATE_
_JNR_ATE_
Posted 20 March 2014 - 06:00 PM
Air cleaner new, I will remove the cats and check them but would assume low/lacking power with a blocked exhaust.
#23 Rockoz
Rockoz
  • 4,054 posts
  • Name:Rob
Posted 20 March 2014 - 06:03 PM
My VE SS used to do about 7.7/100 on the freeway at cruise speed.
About 25/100 having fun on Putty Road
Edited by Rockoz, 20 March 2014 - 06:04 PM.
#24 _JNR_ATE_
_JNR_ATE_
Posted 20 March 2014 - 07:56 PM
How accurate is the digital display?
I got 15.2 at idle this Arvo but it doesn't even alter when ur going up hills or even overtaking.
#25 Neils LX
Neils LX
  • 2,074 posts
  • Name:a
Posted 20 March 2014 - 08:15 PM
Get a tec2 plugged into it and see what it says. Wifes V6 auto VY commonwhore gets over 700klm to tank and uses 7-9L/100klms.
