Hi All,
Just after a little bit of advice in regards to some rust I'm dealing with. Found some rust that is ether hidden from site (under cover a scuff panel), internal (inside of guards at the bottom or light surface rust on the internal of the panels.
So far for the worser parts I'm just scraping the old tar and any loose flakes away then applying a 'rust convertor and primer' (using K&H but similar to the 3M and HiChem versions). The product says no need to sand and able to apply primer and topcoat on top.
Just I'm not sure what to apply next? I was thinking something along the lines of just a enamel wattyl kill rust? I'm not 100% fussed on what it looks like just want it protected in case water get in contact with it again, etc? Or should I be looking at something more along the lines of primer and topcoat process?
Also for the surface rust after light sanding should I also apply the rust convert/primer or skip it and straight to something else like the kill rust?
After all of this I plan on fish oiling/cavity waxing the car and seams, Most of what I'm doing is just trying to protect not repair.
Thanks,
Devon
