The LC workshop manual says the diameter and thickness of the front brake rotor is 10.625" and 0.375" respectively. This equates to a diameter and thickness of 269.776mm and 9.525mm. The replacement rotors supplied by DBA (Disc brake Australia) and RDA are a diameter of 256mm and thickness of 12.7mm. So they are a smaller diameter but thicker. My concern is will the smaller diameter (13mm) affect brake performance and will the thicker rotor (3.2mm) actually fit inside the caliper, considering the maximum allowable wear in the rotor thickness is about 0.7mm. ??? Something doesn't seem right to me.
Has anyone come across this before?
