electronic distributor
2 replies to this topic
#1 rtorana1
rtorana1
  • 249 posts
  • Name:ray
  • Car:lj
Posted 17 April 2014 - 07:51 PM
I want to replace the standard distributor in my 308 HQ motor with an electronic type. I need one which is physically small as the firewall is quite close so probably need one that doesn't have the coil attached.  Any recommendations.
#2 rexy
rexy
  • 3,777 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 17 April 2014 - 08:04 PM
Any Holden V8 HEI you can get your hands on. Add small cap and rotor.
Alternatively ring performance ignition services in Nunawading Melbourne and get hold of a new scorcher distributor.
#3 yel327
  • 13,786 posts
Posted 18 April 2014 - 07:42 AM
As above, leave your points cap and leads on the car, and just use an XD/E Cleveland rotor button on the HEI dizzy. You need a HEI coil though, if you can find an original (6cyl is the same) use a spark lead as a coil lead.
Bridge the pink and yellow wires at the ignition switch to bypass the resistor wire.
