Could I please ask for your opinions on my temperamental 307?
As some of you know the LX has been rego'd and back on the road for two weeks now... And there's an issue. After about 3 hours driving (first big drive for about 3 years) last weekend it developed a ticking, from the passenger side bank. I got her home and inspected and thought maybe it might be an exhaust gasket leak, so I replaced the gasket (which showed signs of a loose fit, but no blow outs etc).
Symptoms
After running it today I've been able to diagnose a few more symptoms:
- ticking coming under rocker cover closest to firewall (at idle from start up, seems to get more pronounced as the engine warms up)
- a "clank" sound every now and then (only every so often and this is worse on cold start)
- trouble idling at cold start up (if I take the air cleaner off it's heaps better, and if I out it back on it chokes on itself and stalls when cold)
It's running a Rochester quad so not sure if this is a common issue
- oil pressure gauge reading normal levels
Engine
I'm not 100% sure what's in the top end, I'm getting a list from my mate that I bought it from and all I know is it's high-comp and reasonably fresh - would only have about 4000km, but had been sitting around for a while.
I am assuming the noise is probably lifter/rocker related, but the "clank" sound and the trouble idling on cold start up has me a bit confused. I don't have the skills or tools to pull apart heads to inspect them, so I was hoping for suggestions... Please?
- any thoughts on what it could be / experience with similar symptoms?
I was hoping to get some advice and things to look out for before I start looking to change cam/rockers/lifters etc.
Thank you.
Andrew
Pic - gasket seems to have had a leak, but not a blow out.
