Hey all.
Cant work this out. Maybe someone with more experience can offer some direction..
- VT series I roller motor (standard as far as I know) in HQ, from unknown origin
- Car runs but doesnt rev well, feels as if its timing is not advancing (always been this way since I've owned it).
- Electricians diagnostic tool wont let him in as VT, but as VS (ecu appears to be VT style, 2 x punk & 1 x blue connector) - yes I know the VS series II is same donk as VT series I
- The diagnostic throws 12 fault codes: 29 EGR position fault, 28 PSA circuit shorted, 27 PSA circuit open, 26 IAT signal unstable, 25 IAT signal voltage low, 24 no vehicle speed signal, 23 IAT signal voltage high, 22 throttle position sensor voltage low, 36 vacuum leak, 32 MAF sensor out of range, 31 theft deterant signal missing, 57 injector voltage monitor fault
- ECu has no conventional serial number but a very faint holden sticker that says 'remanufactured' with a serial number 1227808 - which appears to be a VP ECU serial number (ECU doesnt look like a VP ECU)
- Memcal has a hand written sticker on it that says "blank".
If you can understand that, then any suggestions appreciated.
