What grade of oil should I use to refill the diff on my 6cyl LJ, as the E.P. SAE90 oil stated in the manual is either no longer available or very difficult to find. Is it also correct that the diff only takes 1.4 litres?
Diff oil, what grade
rtorana1
, May 18 2014 08:02 AM
4 replies to this topic
Posted 18 May 2014 - 08:02 AM
Posted 18 May 2014 - 08:56 AM
Yep, 1.4 litres. Can't answer which oil is best to use though.
Posted 18 May 2014 - 12:12 PM
think it's 85W / 90, and Penrite is the going Brand these days hey Ray,
then there is the LSD one too, it will say on the container if it is for LSD. Dave I
Posted 18 May 2014 - 06:01 PM
Had a search on the Penrite website for diff oil for LJ Torana 6cyl and got this.
GEAR OIL 80W-90
Gear Oil 80W-90 is a premium heavy duty, mineral, extreme pressure SAE 80W-90 automotive gear oil meeting the requirements of API GL-5/6 and MT-1, as well as many other manufacturer specifications. It can also be used where SAE 90 and 85W-90 oils are recommended. It is designed for use in differentials, both hypoid and limited slip, manual gearboxes, transfer cases and transaxles in passenger cars, light commercials, 4WDs, trucks, construction, earthmoving and agricultural equipment. Coloured blue.
Key Specifications: API GL-5/GL-6/MT-1/PG-2, MIL-L-2105D, MIL-L-PRF-2105E
Product Codes: GO8090001, GO80900025, GO8090020, GO8090060, GO8090205
Service Refill Capacity: 1.4 Litres. See note 20 below.
Posted 18 May 2014 - 06:35 PM
Thanks for all replies
