ve commodore
11 replies to this topic
#1 grina05
grina05
  • 131 posts
Posted 18 May 2014 - 12:56 PM
ive got a mates commodore thats stopped,will just idle no power.has codes po500,po342,po368 &po300
hes was driving along h/way an started missing,pulled over and would be ok,did this about 3 times till it stopped
im hoping some holden experts may have come across these before
some help would be appretiated, steve
#2 dattoman
  • 16,488 posts
Posted 18 May 2014 - 01:34 PM
v6's are prone to throttlebody issues that require the TB to be replaced
P0500 Vehicle Speed sensor (open circuit)
P0342 RH bank intake camshaft position sensor signal (incorrect)
P0368 RH bank exhaust camshaft position sensor  (voltage high)
P0300 Engine misfire detected
http://www.tech-onli...127efc/3192.pdf
#3 grina05
grina05
  • 131 posts
Posted 19 May 2014 - 09:13 PM
thanks dattoman,the r/h timing chain has failed
#4 _mello92_
_mello92_
Posted 19 May 2014 - 10:05 PM
How many kilometres on this engine?
Service history?
Did it have a distinct rattle on cold start up that went away as it achieved oil pressure?
#5 Neils LX
Neils LX
  • 2,074 posts
  • Name:a
Posted 20 May 2014 - 11:46 AM
Timing chain first place to look. They stretch according to my mate from Holden
#6 Dr Terry
Dr Terry
  • 3,327 posts
Posted 20 May 2014 - 12:36 PM
Quite often an ECU re-flash will fix the problem.
I've seen many Alloytec V6s that throw CAS & CAM codes because the timing chain has stretched slightly. They don't stretch far enough to rattle but the ECU can see the variation. Apparently the original program was too sensitive to this issue, so they've released another program with more tolerance in this area. Try that first, it is a lot cheaper than replacing timing chains etc.
Holden are not alone with this problem, many other cars (including some Toyotas) suffer the same problem.
Dr Terry
#7 mitchg
mitchg
    The guy with the Torailer
  • 3,111 posts
  • Name:Mitch
Posted 20 May 2014 - 12:50 PM
^^ this.
Happened to my grandfather just after he bought his. Thankfully it was under warranty.
#8 grina05
grina05
  • 131 posts
Posted 20 May 2014 - 09:21 PM
thanks guys,i replaced the chains 2yrs ago(done about 100.00k since) when i pulled the r/c off the chain wasnt on the cam gears
ive done a leak done test on it an doesnt appear to have bent the valves.i still need to pull timing cover off an see wat damage its done in there
#9 grina05
grina05
  • 131 posts
Posted 20 May 2014 - 09:28 PM
an mello92,i dont think it was serviced very often when i 1st seen it.as theres black carbon shit everywhere
and its still everywhere
#10 rodomo
  • 18,046 posts
Posted 20 May 2014 - 10:32 PM
I've seen 1 snapped chain doing roadside service and also the oil gauze for the cam timing blocked due to lack of service.
#11 _mello92_
_mello92_
Posted 21 May 2014 - 06:12 AM
I suspected that may have been the case.
If/when you pull out apart, let us know if any particular gallery seems to be blocked, condition of chain guides etc please.
Would like to know for future reference.
#12 grina05
grina05
  • 131 posts
Posted 21 May 2014 - 09:49 PM
ive pulled the cover off,the tensioner is seized compressed,the plastic guide the chain rubs on has come away from main guide and rapt itself around bottom gear
(opposite the tensioner guide)
were abouts is the gauze for the valve timing
