Hi, just want to check that I have the heater hoses set up correctly. 74 LH, pre pollution. Do I need to have a twin outlet thermostat housing and run a bypass hose from it to the plugged water pump inlet? or is it ok to leave it as is?
Posted 15 June 2014 - 08:36 PM
Posted 16 June 2014 - 07:48 PM
im no expert mate but i think thats fine.It doesnt matter where the waters coming from as long is it has an in and an out. just have to make sure the heater tap is in the correct hose.
Cheers jake
Posted 13 August 2014 - 10:13 AM
Posted 13 August 2014 - 10:17 AM
Seeing as you are not doing restoration, do yourself a favour and fit the twin outlet with the thermostat bypass and junk that chrome neck.
Posted 13 August 2014 - 11:37 AM
The LH intake manifold used a single inlet thermostat housing.
Picture from this thread.
The LX ADR27A version used a twin inlet thermostat.
Both setups basically do the same thing which is to allow coolant to bypass the thermostat via the heater. The heater on the LH/LX Torana does not have a tap to stop coolant flow through the heater.
The short hose from the water pump to the thermostat on the LX ADR27A version allows more coolant to bypass the thermostat than the LH version. Presumably this was done due to the slightly higher operating temperature of the ADR27A engines. Increasing the coolant thermostat bypass increases the coolant flow through the heads when the thermostat is closed. This provides a more even head temperature before the thermostat opens and reduces the possibility of hot spots.
As it is the the stock manifold then I would use the LX ADR27A version. You can buy reproduction hoses to suit the LX ADR27A version from sstorana.
Edited by ls2lxhatch, 13 August 2014 - 11:46 AM.
Posted 13 August 2014 - 09:12 PM
leighlh, the hose from the water pump is original HQ. The thermo hose I went to supercheap and went through their hose racks to find one that was a similar shape. From memory it was some kind of commodore hose I think!
Posted 13 August 2014 - 09:32 PM
