LS1 conversion to LH
50 replies to this topic
#1 _Hussyslr_
_Hussyslr_
Posted 02 August 2014 - 01:33 PM
Hey guys,
I am ready to put a motor in my LH and I wanted some information on weather I should put an LS1 or a 308 in?
I have had so much misinformation on the LS1 conversion some say its easy and you can buy everything you need and some say its a pain in the arse! My budget for motor and trans is $7,000 and I want no less than 400hp.
It was a 6cy and I know I need a bigger break booster and raidiator / new springs and shocks but what else would I need if I go either way?
Thanks guys for your help in advance!!
Regards, Hussyslr.
#2 DanWA
DanWA
  • 2,440 posts
  • Car:LS1 LX 4 Door
Posted 02 August 2014 - 01:37 PM
You're not going to get 400hp from a 308 for $7k
My LS1 conversion has been a headache from the start and over tripple your budget
The easiest thing you could do with your small budget is 308 conversion which is super straight forward, just forget the 400hp part
#3 _LHSL308_
_LHSL308_
Posted 02 August 2014 - 01:56 PM
I think you would be on an extremely tight budget. If you could allow yourself 10K and put the engine in yourself then I think you could do it pretty easily. I have a 400HP 308 which was rebuilt about 1 year ago. Just the carbie, inlet manifold and extractors were close to 2K. It cost about 5K to get all the machine work done, rebuild heads then a few thousand to get my mechanic to put it all back together and reinstall the engine.
Happy to help you out with any questions you might have whichever route you go down.
#4 _LH SLR 3300_
_LH SLR 3300_
Posted 02 August 2014 - 05:26 PM
I bought an rough VL Commodore unfinished project with a 380HP EFI head 304, full manual shift Tri-matic for $5000. Pulled the engine/trans & sold the rolling shell for $1200 which I put towards headers, sump, engine mounts etc to fit in one of my LH Toranas. With a 3.7 geared diff, that combo ran 12.5@109mph on skinny street tyres. I've also seen complete reconditioned 355 Holden V8s for sale here for $7000, 400HP is easy to make out of a 355 & are more or less a bolt in fit without anywhere near the headaches as a LS conversion come rego time. There are plenty of ways to build a decent powered street car on a budget, just do your research thoroughly. ask plenty of questions & trawl internet sales sites like Gumtree & eBay. Just my opinion. Best of luck which ever way you choose.
#5 _LS1 Taxi_
_LS1 Taxi_
Posted 02 August 2014 - 05:52 PM
Good advice from Matt above - and is what I would do if I had your budget.
If you do decide to go the LS route feel free to PM me for info/help/whatever as I've been through the yards of shit that is the LS conversion into torana.
#6 rexy
rexy
  • 3,758 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 02 August 2014 - 06:12 PM
The Holden V8 install will be much cheaper, particularly if you have to pay people to do a lot of the custom fiddly things that an engine swap requires. Will also not require engineering.
#7 dattoman
Posted 02 August 2014 - 06:14 PM
Double your budget
There is not much chance of achieving what you want with what you have
Unless you have already sourced the big diff, brakes, radiator , gearbox/clutch/convertor etc thats all required to go along with the engine of your choice
I could spend $7k on the supporting parts without spending a cent on buying a motor
#8 _Hussyslr_
_Hussyslr_
Posted 04 August 2014 - 07:45 PM
Thanks guys for all your feedback . You have all made up my mind! I am building my own 308 / 355 stroked.
I will look for a 308 in good condition to start with and go from their! I have made a few inquiries with engin builders and they can build me a motor with 350hp for $5,500.
And that's with all good equipment. I have been told that I should buy a black motor! Red, blue or black, dose it make a difference with the roadworthy and would I need an engeniers certificut with a blue or black motor? I know the blck motor has better heads!
I am getting my LH painted next week! I am excited as this has been a father and son project and we want it ready for Christmas!! When I get it back I will run a full thread of the build!
I really appreciate all your opinions and help guys!!
If any one has a good 308 for sale let me know!
Regards, Hussyslr
#9 ls2lxhatch
  • 5,335 posts
Posted 04 August 2014 - 08:04 PM
I would compare the price of the rebuilt 308 vs a new small block chev crate motor with a carby.
#10 rexy
rexy
  • 3,758 posts
  • Name:Rexy
Posted 04 August 2014 - 08:31 PM
And when you do the sums make sure to add the cost of engineering the engine swap to the Chevy price.
#11 ls2lxhatch
  • 5,335 posts
Posted 04 August 2014 - 08:56 PM
Engineering a SBC should be less than $500. You will need engineer for the brakes, gearbox and diff regardless of your engine choice.
Edited by ls2lxhatch, 04 August 2014 - 08:58 PM.
#12 torana_nick
torana_nick
  • 759 posts
  • Name:Nick
  • Car:LH Torana Project
Posted 04 August 2014 - 09:03 PM
Is this true for Melbourne?
#13 _LS1 Taxi_
_LS1 Taxi_
Posted 04 August 2014 - 09:24 PM
Was the best part of a gorilla to engineer the LS1 into my LX...
#14 ls2lxhatch
  • 5,335 posts
It is true in all states. If you fit and engine, brakes, gearbox or diff that was not factory option for your car then it needs to be engineered.
#15 rexy
rexy
  • 3,758 posts
  • Name:Rexy
Posted 05 August 2014 - 12:32 AM
Not true. In vic if you fit a 308 to a LH/ LX it will not require engineering. Nor did fitting a nine inch diff or 5 speed gearbox on direct advice from vicroads technical department.
#16 ls2lxhatch
  • 5,335 posts
Posted 05 August 2014 - 02:48 AM
You either spoke to the wrong person or the information is out of date. Have a read of the VIC Roads Modification Guide.
Any engine, gearbox, diff or brakes that were not a factory option on the Torana require engineering. If you want 350+ HP then you are going to want to fit a stronger gearbox, diff and better brakes all of which will require engineering.
Fitting a 308 in a LH/LX does avoid the cost of engineering the engine as it is a factory option.
However new SBC components are cheap. It could work out that even with the additional engineering cost you could build a SBC or buy a SBC crate motor cheaper than the cost of sourcing a suitable 308 and building a 355.
Eagle Auto Parts Australia
#17 rexy
rexy
  • 3,758 posts
  • Name:Rexy
Posted 05 August 2014 - 07:39 AM
Instead of reading guides you should try talking to people. I have nearly always found them reasonable and helpful. The last time of several times I went through this process the vicroads technical staff, the RWC inspector and the vicroads inspection team were all on the same page. No engineering required for straightforward mods such as a Supra gearbox swap or nine inch conversion.
None of the fine officers of the law who have looked at any of these have mods have raised an eyebrow either.
#18 _LS1 Hatch_
_LS1 Hatch_
Posted 05 August 2014 - 08:51 AM
Ahhhhhh....the one nice thing about here...do what ever you want to a car, and no one cares. :D
The only problem is....is just what some people do to them..lol
By the way, I think the LS is an awesome way to go, but with a tight budget and depending on your own skill, obviously a 308 based engine is a lot easier to just drop in and go.
#19 _LS1 Taxi_
_LS1 Taxi_
Posted 05 August 2014 - 10:08 AM
It depends on the engineer I suppose. My guy didn't engineer my 9" or 4L60e auto box BUT he did engineer my brake upgrades, LS engine swap and fuel system changes.
Sounds like a great place to be a rodder Jeff :)
Obviously I agree with you about the LS being a great option but it really depends how handy and patient/resilient you are. Some blokes just aren't up for installing/pulling an engine 10+ times modifying shit to make it all fit.  IMO, the juice is worth the squeeze though :)
#20 ls2lxhatch
  • 5,335 posts
Posted 05 August 2014 - 11:58 AM
Are VIC Roads are currently enforcing engineering requirement for a brake upgrade that was not a factory option?
If you need an engineer for a brake upgrade then you may as well get them to sign off on the gearbox and diff as they are only visual inspections. If you have a engineer for the brakes then it shouldn't cost much more to get them to sign off on a SBC engine swap. VIC Roads could decide tomorrow to start enforcing their rules so you may as well make the most of the engineer while they are there.
The OP could budget $1000 for engineering the SBC and then compare the cost of fitting SBC verses the cost of building and fitting a 355.
Edited by ls2lxhatch, 05 August 2014 - 11:59 AM.
#21 DanWA
DanWA
  • 2,440 posts
  • Car:LS1 LX 4 Door
Posted 05 August 2014 - 05:41 PM
Brakes and diff are definate engineering 'have to's"
Me personally i regret going the LS route and should have put a chev in it
#22 _LH SLR 3300_
_LH SLR 3300_
Posted 05 August 2014 - 09:15 PM
My engine builder recommends using a later VS-VT block as they tend to have less internal corrosion in the water jackets than older blocks & are factory relieved for the 355 crank/rods. A lot of people hang shit on the so called "plastic" engine, but with the parts & technology available today, a good engine builder can get them to make decent reliable power. It is true a SBC is cheaper to build & you get more bang for your buck, but you still need to have it pass an engineer report, & in NSW at least, an emissions test. This can be difficult if you run a high lift camshaft with a big Holley carb. Same can near be said for the LS1, even in near stock configuration, they make excellent power, but as with the SBC, the extra you spend on fitting either engine to a Torana & getting it passed for engineering/registration, you can build a 355 Holden that will out perform them without the red tape run around. Just my opinion :)
#23 rexy
rexy
  • 3,758 posts
  • Name:Rexy
Posted 05 August 2014 - 11:06 PM
It depends on what you consider a factory option. I have had both the milled down HQ disc conversion and the HQ stubs and brakes versions passed in vic without incident.
Most of the V8 conversion items for a Holden are readily available to the patient builder second hand. This also widens the price gap.
#24 DanWA
DanWA
  • 2,440 posts
  • Car:LS1 LX 4 Door
Posted 06 August 2014 - 08:34 AM
Yeah somehow i don't think thats going to happen
#25 myss427
myss427
  • 1,636 posts
Posted 06 August 2014 - 11:44 AM
I have done a few LS1 conversions, best bang for buck. To put in a stroker 308, you end up replacing most of the driveline anyway for all the additional power, why not get a better mannered, higher econnomy and smoother running engine that probably have more go as a bonus.
