Heat resistant clear coat
7 replies to this topic
#1 UCSLE
UCSLE
  • 714 posts
  • Name:troy
  • Car:Goggomobil
Posted 26 August 2014 - 04:02 PM
Anyone know of a good clear coat that is Heat resistant for polished alloy.
The ones i have been finding all say to use a primer .
#2 sibhs
sibhs
  • 2,720 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 26 August 2014 - 05:23 PM
Check out the specs on KBS diamond coat. Could be what your after.
#3 _judgelj_
_judgelj_
Posted 26 August 2014 - 05:33 PM
whats it for?
#4 UCSLE
UCSLE
  • 714 posts
  • Name:troy
  • Car:Goggomobil
Posted 26 August 2014 - 06:26 PM
brake calipers , transmission , manifold and other stuff like that . Going to try it out on the calipers first and see how it goes .
#5 _Bomber Watson_
Posted 26 August 2014 - 07:48 PM
Calipers may be an issue.
Trans and manifold, dont get that hot, any polyurethane clear coat will handle the heat no worries.
#6 dattoman
  • 16,488 posts
Posted 26 August 2014 - 08:01 PM
Also have a look at POR15 Glisten PC
http://www.por15.com...Coat_ep_75.html
#7 _judgelj_
_judgelj_
Posted 26 August 2014 - 08:55 PM
Oh shiny! I wouldnt bother with the manifold as a polish will do it's bit to repel moisture and prevent oxidisation. As for the brakes and trans, sounds like a good idea.
#8 Beans
Beans
  • 26 posts
  • Name:Geoff
  • Car:72 LJ XU-1, HQ GTS Coupe
Posted 27 August 2014 - 01:58 PM
Cerakote High Temp Coatings in the US have a few high temp ceramic clears.
Some are good to 600 deg C.
http://www.cerakoteh...p.com/finishes/
The aussie distributor (slr coatings) is in Brisbane.
You can purchase directly from them.
