will any holden rim, fit on my uc torana?
17 replies to this topic
#1 _UC Kid_
_UC Kid_
Posted 10 September 2014 - 07:32 PM
Uc,rims, wheels, holden, skizes,stud pattern
#2 Ice
  • 15,215 posts
Posted 10 September 2014 - 07:39 PM
Hq to wb wont fit fact
#3 _Bomber Watson_
Posted 10 September 2014 - 08:14 PM
Only 4.25" x5 PCD rims will fit. So no HQ onward, no commy, with the exception of 4 cylinder VB-VK etc.
Most early holdens ran 4.25, so pre HQ, but early H series (HK-G-T etc) has a different offset and will stick out of the guards a bit with say a 6-7" rim.
Not sure on E and F series, but i think they are the same offset as HKTG.
Edited by Bomber Watson, 10 September 2014 - 08:15 PM.
#4 _Lazarus_
_Lazarus_
Posted 11 September 2014 - 11:16 AM
Got this off the Old Holden site. Not sure how accurate it is.
FE - HR:  +6mm
HK - HT:  +30mm
If this is correct then HK - HT (HG ?) is very close to UC but 14".
Edited by Lazarus, 11 September 2014 - 11:19 AM.
#5 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
  • Car:UC S̶u̶n̶b̶i̶r̶d̶ 5000!
Posted 11 September 2014 - 12:36 PM
I've got HK rims on my UC and the offset seems ok
#6 TerrA LX
Posted 11 September 2014 - 05:31 PM
Careful, some hk-ht-hg rims need a spacer on the rear to fit factory drums, if you have them.
#7 _Lazarus_
_Lazarus_
Posted 11 September 2014 - 07:57 PM
What difference is there in the spigot hole diameter, if there is any ?
#8 yel327
  • 13,771 posts
Posted 11 September 2014 - 08:07 PM
HK are a different offset to HT-HG. Same for both 5" and 6".
To answer the question re stud pattern the only Holdens with Torana pattern were FE to HG. Plus other Toranas and 4cyl Commodore as Bomber says.
#9 _Bomber Watson_
Posted 11 September 2014 - 08:25 PM
What pattern did the early early girls run Yel?
I've seen heaps with Torry pattern, but assume this was just a common mod back in the day?
#10 dattoman
Posted 11 September 2014 - 08:36 PM
5 x 6.375"
#11 _Bomber Watson_
Posted 11 September 2014 - 08:57 PM
Wow, landcruiser pattern :P
#12 yel327
  • 13,771 posts
Posted 13 September 2014 - 08:13 AM
Yeah, they look like a VW hub in some ways.
#13 Dave6179
Dave6179
  • 577 posts
  • Name:David
  • Car:HJ, VN, VX SS
Posted 13 September 2014 - 11:04 AM
FC rims don't fit HR, they don't sit right on the drum... something warps as the nuts are done up. So no, not everything fits everything else.
#14 Dr Terry
Dr Terry
  • 3,341 posts
Posted 27 September 2014 - 05:34 PM
Landcruiser have a 6-stud hub, don't they ?
Dr Terry
#15 Dr Terry
Dr Terry
  • 3,341 posts
Posted 27 September 2014 - 05:37 PM
Correct. FE-EH rims won't fit over HD/HR drums without distorting them & they won't clear most disc brake calipers either.
It's better to stick to the later model wheel rims to avoid dramas, even though the PCD stud pattern is the same.
Dr Terry
#16 _Bomber Watson_
Posted 27 September 2014 - 05:45 PM
Dr Terry
New ones are five stud.
I actually have no idea what the PCD of a five stud cruiser rim is, My comment was made mostly in Jest, but it would be somewhere close.
#17 dattoman
Posted 27 September 2014 - 07:49 PM
139.7mm x 6
150 x 5
#18 _Bomber Watson_
Posted 27 September 2014 - 07:58 PM
That answers that question.
