Keep blowing 15amp tell tale fuse.
2 replies to this topic
#1 _yomikey_
_yomikey_
Posted 25 September 2014 - 03:50 PM
Okay, I have an LJ 4 door, she has been up on stands for the last month, when I parked her up there was nothing wrong electrically. I have since replaced the rear brake drums, shoes and hand brake cables. I had the seats out as well. I have put everything back. Looks awesome. BUT, now when I turn on the ignition the fuse blows. What does that circuit run?? The battery has 12 volts. The battery was disconnected while I was working on the car.
#2 Rockoz
Rockoz
  • 4,046 posts
  • Name:Rob
Posted 25 September 2014 - 04:13 PM
Check all the wires at the battery for starters.
Make sure that any extra wires particularly alternator related got connected to the right terminals
#3 _yomikey_
_yomikey_
Posted 10 October 2014 - 05:47 PM
Update, the previous owner had put a circuit in for a fuel solenoid, a wire was pinched and shorting out, and the switch itself was dodgy. Replaced the switch, relocated it and replaced the wiring. All sorted.
