I have always removed the engine with a crane. Dropped the k frame to remove the sump once but I prefer to lift the engine out with a crane. Only my opinion. Others prefer to drop the k fame with engine in it and lift the front of the car up with the crane. I can't because my drop tank is only about 4" off the ground.
Some things that have to be removed differ from car to car. This is what I do to yank mine out.
Put car up on stands
Remove bonnet- only 4 bolts and its so much easier to work on.
Drain coolant
Remove radiator- gives me more room and avoids damage
Remove dizzy- to avoid it hitting or breaking.
Disconnect wiring harness. mine has a plug. Not sure on standard vehicles.
Remove exhaust. Twin 3" so they have to get out of the way on mine
Remove extractors. Mine are a pain. 1 7/8 single things that only go in and out one way.
Remove drive shaft
Put trolley jack under gear box. Take the weight of the box and remove cross member. Make sure you use a block of timber of metal plate to spread the load
Put a bottle jack under the sump. Make sure you use a block of timber of metal plate to spread the load. This is to support the engine while you take the box off. Engine crane could also be used.
Remove the converter bolts.- mines an auto. you would have a clutch cable or linkage to remove
Remove the bell housing bolts
Lower and slide the gear box out the way
Connect engine crane. I use a chain at the front and a small come along at the back. You can get lifting plates and levellers from repo etc that look good
Take the weight of the engine and remove engine mounts.
Lift the engine carefully Mine has to come up and out a bit first then I lower the back to get the angle I need. Engine vary depending on the sump.
You can also remove the starter and alternator if you want. Less crap in the way the better IMO. I have done it both ways.
Not sure i this helps but it what works for me anyway.
Plenty of help on her and I am sure other will have different ways for you to use.
Cheers Paul
Remove it as quickly as possible, then replace it with a red 6.
That's just silly. Lol
