Engine Oil Cooler - tips?
16 replies to this topic
#1 _jklumpp_
_jklumpp_
Posted 18 November 2014 - 07:54 PM
Background
Under normal running I have no problems with oil pressure - 20psi at idle, and around 45psi at revs.
But after a run down the freeway, or a few laps on the track I start to get some issues....
I have an 18psi sender connected to my warning light & a buzzer. At idle after a hard run, psi can drop to around 10-15, and the buzzer sqeals.
I also have an occasional 'blip' on the warnign light/buzzer under hard cornering &/or braking (pressure is fine in a straight line)
My way of thinking is that when the oil get's too hot, it get's too viscous and:
A. causes the pressure to drop at idle
B. causes the oil in the pan to 'slosh' under heavy braking/cornering away from the pickup.
I have glanced at the gauge on the track during the braking/cornering when the buzzer 'chirps', and it shows around 10psi - probably at around 2500-3000rpm.
I use Penrite HPR30, and have tried going to HPR40, but it didn't appear to help.
My car uses a high energy sump, and I have put a 3/4" return line in from the rocker cover to the sump to make sure the oil doesn't fill up the rocker cover at revs.
As the issue only happens after a few laps, or after a long/higher rpm run, I'm thinking of running an oil cooler to try & keep the oil temp down (and also increase oil capacity slightly)
Questions
My oil pump runs an external pickup direct to the sump via a 3/4" pipe/hose. I assume that it would not be a good idea to use this external pickup to 'suck' the oil through the cooler? I imagine it would take some time to get oil on a cold start?
So I assume the better option would be to run an adapter on the oil filter mount? Would the anti-drainback valve on the filter stop the oil draining out of the cooler?
Is there a 'better' type of adapter? on ebay they vary from $20 - $150 for what essentially looks like the same thing...
Is there any specific type of cooler I should be looking for?
Would a transmission oil cooler do they job, or does it need to be engine oil specific?
I assume the best place for mounting the cooler is in front of the radiator (plenty of capacity in my radiator so coolings not a problem)
Any other tips?
Edited by jklumpp, 18 November 2014 - 07:54 PM.
#2 RallyRed
  • 8,211 posts
Posted 18 November 2014 - 08:40 PM
Might be something to do with engine clearance opening up at temp as well?
i.e bigger clearances = less back pressure, but still plenty of oil flow.
I remember getting all worried about oil pressure ( see separate thread ) at one stage, ...felt better after asking Old Johnno
who DOES know about these things.
From memory he said it was more about flow than pressure. i.e you can have wonderful pressure and its not necessarily good as
the engine needs the oil FLOW to be lubricated. Pressure is an indication that there should be flow if all is well, but pressure
is not the be all and end all.
Cooling the oil might make it thicker, and therefore make more backpressure as the pump tries to force it thru the engine, but is that what you really want?
Anyway..I'll leave it up to someone who is more schooled in this area.
p.s. 10psi at 3000 does seem a little low??( have you fitted a 2nd gauge even as a test?
I did and it showed the GTR dash gauge was definitely reading low.
Regards
#3 warrenm
warrenm
  • 2,130 posts
  • Car:1972 LJ Torana
Posted 18 November 2014 - 11:06 PM
You mention that you get a blip under hard cornering & braking, this could indicate that the oil pickup is sucking air, which as you know air doesn't lubricate. Have you tried running more oil in the sump, to allow for oil that may be in the top of the motor, I'd run a litre more than the std dip stick "Full" mark as a trial. What type of pickup is in the sump?
#4 Dave6179
Dave6179
  • 577 posts
  • Name:David
  • Car:HJ, VN, VX SS
Posted 19 November 2014 - 07:24 PM
Why no baffles? I had the lil red light come on with heavy braking years ago. New (second hand) race engine (from an actual race car) had a baffled sump... no more red lights. I've also gone back to 20/50 oil, from 15/40. The lighter oil let the engine 'rumble' at cold idle, not there with the thicker oil.
#5 ckblock
ckblock
  • 40 posts
  • Name:richard
  • Car:lc xu1 lc group c torana
Posted 19 November 2014 - 08:31 PM
I had the same thing in one of my xu1,s when you came in off the track.I tried lots of things pump mods etc but the thing that worked was as simple as running MOTUL 300V competition 15W50 and over filling.I wont run anything else in the race cars now as it raised the idle pressure by 8 to 10 psi
#6 rexy
rexy
  • 3,777 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 20 November 2014 - 01:19 PM
This is the same advice I followed with success.
I used to get the oil warning light flickering with hard braking after a hard run up through the gears.
#7 _duggan208_
_duggan208_
Posted 28 November 2014 - 11:46 PM
Yeah, I looked into an oil cooler a while ago, my oil pressure is really sad, I think I've just stuffed my main bearings. I found out that unless your oil temp is going over 100 degrees then you don't need an oil cooler and that most oils are designed to run up to 100 degrees. I would think that cooler oil is thicker and therefore increases friction and decreases oil flow. Not to good for main bearings. I noticed that you have an external oil pick up, I'm going to get one of these. Does the connection on the sump to the oil pump has a fitting or does it have a pipe of some discription that goes to the middle of the sump? I've seen wet sumps that have trap doors to control oil surge in mainly race engines. Sounds like you will have some fun playing around with sumps. I'm sure that a trannie cooler is different that an engine cooler, can't remember the difference.
Regards
#8 rodomo
  • 18,063 posts
Posted 29 November 2014 - 06:32 PM
I run 6 litres in the Grease Slapper sump.
#9 N/A-PWR
  • 9,644 posts
Posted 29 November 2014 - 06:35 PM
That's great Info Rob.
#10 Litre8
Litre8
    Thrillseeker
  • 2,399 posts
  • Name:Howard
  • Car:1976 LX SLR8000
Posted 29 November 2014 - 09:38 PM
I think all modern engine oils are designed to cope with temperatures over 100c.  I understand a good mineral based oil should safely handle to around 115c and a synthetic to about 140c.
#11 _duggan208_
_duggan208_
Posted 29 November 2014 - 11:33 PM
Hi, howard, did you build a really hot turbo 202 in an LH a long time ago and had a feature in SM magazine?
#12 N/A-PWR
  • 9,644 posts
Posted 30 November 2014 - 12:41 AM
In the past,
I noticed that engine oil plays a part in keeping the engine cool too, as when the oil is at the low mark on the dip stick,
 the motor has a higher temperature, because the oil is hotter having less oil, like wise on a hotter day the oil gets hotter quick and stays there.
So I can imagine an oil cooler to be switched on or off as needed would be handy.
I wonder what coolers the dry sump motors use?
#13 N/A-PWR
  • 9,644 posts
Posted 30 November 2014 - 01:02 AM
Just looked up Dry Sumps, and is heaps of information there, including Images:-
#14 warrenm
warrenm
  • 2,130 posts
Posted 30 November 2014 - 05:19 AM
In the past,
I can't remember the exact figure, but the oil does the majority of the "cooling" & the water takes care of the rest.
#15 N/A-PWR
  • 9,644 posts
Posted 30 November 2014 - 09:36 AM
That makes a lot of sense Warren.
Like Button for You.  :spoton:
#16 Litre8
Litre8
    Thrillseeker
  • 2,399 posts
  • Name:Howard
Posted 30 November 2014 - 10:16 AM
Yes, Litre8 was at one stage running a 202 (208 actually) with an upgraded NGM Strata VI kit . More details under the General -> History tab on the Litre8 website.
It was featured in the July-Aug 1986 Street Machine.Magazine (and running 16"x9" Simmons way back then)
#17 ozyozyozy
ozyozyozy
  • 953 posts
Posted 30 November 2014 - 04:52 PM
From my experience, if your going to the track and doing more than say 5 laps at a time an oil cooler is needed.
I find the type of oil affects pressure good synthetic oils recover faster when hot and also handle higher temps but not always good for flat tapper cams.
It's not uncommon for the pressure to drop when hot.
There is a few mods that are required internally that will help with pressure too.
10 psi at 3000rpm on the track is bad.
A good sump for the track is an absolute must, DO NOT skimp or you will suffer.
To be really honest if your going to see the track with a 308, after all the issue some friends and myself have had I see only 1 option dry sump.
In the time I have had mine fitted I would have rebuilt my wet sump motor 3 times by now.
The other point people don't think too much about with dry sumps are they are generally filtered more and due to the design of the oil tank there much better at separating oil from air which is a big deal in engines.
End of the day there is no 1 single main fix, there will be a number of small things that are required to be done.
