LC GTR inlet manifold
16 replies to this topic
#1 _Jarvo74_
_Jarvo74_
Posted 28 December 2014 - 12:25 AM
Does anyone know the correct part number for a LC GTR inlet manifold? I'm getting different numbers between what's listed in the parts catalogue and what I'm seeing on "genuine" cars.
#2 dattoman
Posted 28 December 2014 - 12:43 AM
Don't confuse part numbers with casting numbers
#3 _ljlhtorana_
_ljlhtorana_
Posted 01 January 2015 - 03:58 PM
Hi my parts book is part no7434447 ,don't no if this is correct or a mistake in parts book??
I looked at some old post all asking same question, no definite answers.
#4 S pack
  • 15,743 posts
Posted 01 January 2015 - 04:29 PM
7434447 is the part number for the GTR 2600S inlet manifold.
7433690 is the part number for the GTR 2850S inlet manifold.
Problem is you won't find a manifold with these part numbers cast in them.
The part number cast into the manifold is the part number for the bare manifold. Once you add the carburetor mounting studs to the manifold the spare part number changes, hence the number in the book is different to the number cast into the manifold.
#5 _Jarvo74_
_Jarvo74_
Posted 03 January 2015 - 10:31 AM
If this is the case how do I then identify a factory fit LC GTR manifold?
#6 S pack
  • 15,743 posts
Posted 03 January 2015 - 11:22 AM
For the 2600S engine you want a manifold with casting number 7434446 - P
#7 TOERUNNER
TOERUNNER
  • 630 posts
  • Name:RODNEY
  • Car:73 lj gtr 73 lj 2 dr S
Posted 03 January 2015 - 12:21 PM
were those manifolds only on the  lc gtr or is that the same manifold as 186 S. cheers Rodney
#8 S pack
  • 15,743 posts
Posted 03 January 2015 - 12:33 PM
Yes, the same manifold on the 186S.
HR 186S may be slightly different though?
#9 limo
limo
  • 2,673 posts
Posted 03 January 2015 - 08:44 PM
Question, does the GTR manifold have mounting points for auto kick down? Manual HR 186S didn't I thought but later 186S did
#10 Dr Terry
Dr Terry
  • 3,329 posts
Posted 04 January 2015 - 09:14 PM
No WW manifold had any provision for the Powerglide kickdown. It wasn't required, the rod to the auto connected directly to the carby.
Dr Terry
#11 RallyRed
  • 8,179 posts
Posted 05 January 2015 - 05:58 AM
arh.......Dr Teety.........I think your turning Japanese, I think your turning Japanese, I really think so...ha ha
#12 limo
limo
  • 2,673 posts
Posted 05 January 2015 - 06:35 PM
Dr Teety
this refers to the HR and HK 186S with powerglide I assume,
so later 186S with Trimatic had the posts and a bracket for cable to gear box, is that right?
any thoughts on my original question?
the 7434446_P seems a bit elusive
Edited by limo, 05 January 2015 - 06:49 PM.
#13 TOERUNNER
TOERUNNER
  • 630 posts
  • Name:RODNEY
Posted 05 January 2015 - 07:28 PM
just sold a 7434446-p to Shane  who started this topic
#14 Dr Terry
Dr Terry
  • 3,329 posts
Posted 06 January 2015 - 05:49 AM
No, the Tri-matic kickdown was operated by the cross-rod on the firewall, near where a clutch master cylinder is sometimes mounted.
Dr Terry
#15 r2160
r2160
  • 712 posts
  • Name:Glenn
  • Car:2/71 LC GTR, 4/71 LC 4 'S'
Posted 06 January 2015 - 07:30 AM
Wasnt the trimatic kickdown a cable on the LC's or was the 4 door and GTR kickdowns different?
My 4 door LC has a cable kickdown that connects to the throttle bracket attached to the firewall.
glenn
#16 S pack
  • 15,743 posts
Posted 06 January 2015 - 08:02 AM
Cable kick down on LC/LJ trimatic and GTR were 4spd manual only.
#17 Dr Terry
Dr Terry
  • 3,329 posts
Posted 06 January 2015 - 09:31 AM
<p>Th
