just curious thats all
Posted 23 July 2006 - 06:14 PM
Posted 23 July 2006 - 06:21 PM
Posted 23 July 2006 - 06:44 PM
Posted 23 July 2006 - 07:38 PM
Posted 23 July 2006 - 09:05 PM
Posted 23 July 2006 - 09:14 PM
Posted 23 July 2006 - 09:37 PM
Posted 24 July 2006 - 06:49 AM
Posted 24 July 2006 - 07:52 AM
in the lower gears at lower road speed it is beneficial to use the clutch on the gear change to avoid blazing the tyres on the change......if he flat shifted from first to second while still turning out of a corner i could almost guarentee he'd end up facing the other way.....when using the clutch you can add a lil more progression the the delivery of powerI also noticed he would use the clutch once while up-shifting/accelerating when first coming out of corners, then just slammed thru the rest of the gears without clutching ? Why use the clutch for the first shift and not the rest ?
Posted 24 July 2006 - 07:57 AM
Posted 24 July 2006 - 08:37 AM
Posted 24 July 2006 - 08:57 AM
Posted 24 July 2006 - 09:52 AM
Posted 24 July 2006 - 11:17 AM
Posted 24 July 2006 - 11:44 AM
That's the one Greg. Also, not really having driven the track before and trying to post a good time. Arrived at the tight hairpin at about 80 km/h. Firm brake, mash accelerator, flick.Thinks of Wakefield park hey Yella.....
You just about need the handbrake at that place!
Cheers Greg..
Posted 24 July 2006 - 12:08 PM
Posted 24 July 2006 - 12:11 PM
The printout I saw was from the Perkins 95 Bathurst winner after practice at Oran Park in 97 or 98, so yeah reasonably old. However, I'm told yes, you can still physically over rev them for a split second in the same mannerRed... I use this gearchange system on my Walky....
as for the overrev.... that's not what the data from my data logger would suggest!
Must be a Very old system that your referring to.
Cheers Greg..
Posted 24 July 2006 - 12:12 PM
The printout I saw was from the Perkins 95 Bathurst winner after practice at Oran Park in 97 or 98, so yeah reasonably old. However, I'm told yes, you can still physically over rev them for a split second in the same manner. I also remember Neil Crompton refering to this on one of the RPM shows, or at one of the races, and it was Skaife they were watching at the time.Red... I use this gearchange system on my Walky....
Cheers Greg..
Posted 24 July 2006 - 12:57 PM
