What diff ratio
22 replies to this topic
#1 _LXHATCH4ME_
_LXHATCH4ME_
Posted 11 March 2015 - 11:46 AM
What diff ratio should I get.
I have:
285/30/18 tyres
tyre diameter is 24.73"
100 kph is about 3050rpm
Aussie 4 speed so 4th gear is 1:1
Engine V8 (308) no real specs on it, its old and tired, in need of a rebuild.
I calculate it that my diff ratio is about 3.55
I would like to lower the rpm to a suitable highway cruising rpm. What diff ratio should I get.?
Edited by LXHATCH4ME, 11 March 2015 - 11:57 AM.
#2 S pack
  • 15,749 posts
Posted 11 March 2015 - 12:59 PM
3.08:1 should drop it down to around 2800 rpm or less at 100kph.
#3 BIG KEV
BIG KEV
  • 1,218 posts
  • Name:Kevin
Posted 11 March 2015 - 01:32 PM
Go 4:11 and have some fun
#4 _ljxu1torana_
_ljxu1torana_
Posted 11 March 2015 - 03:22 PM
2.7ratio @100 k/ph is 2700-2800.3.08 is 3000rpm @100 k/ph,3.36 is 3300 rpm @ 100k/ph and so on.
#5 Bigfella237
Posted 11 March 2015 - 03:36 PM
Using your tyre size @ 100km/h in top gear, I get these revs for the following diff ratios...
2.60:1 = 2,200 rpm
2.78:1 = 2,350 rpm
3.08:1 = 2,600 rpm
3.36:1 = 2,850 rpm
3.55:1 = 3,000 rpm
3.90:1 = 3,300 rpm
4.11:1 = 3,500 rpm
...based on your tyre size doing 507 revolutions per kilometre.
(Please note that I rounded off the rpm figures)
#6 rexy
rexy
  • 3,772 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 11 March 2015 - 10:13 PM
You should get an overdrive 5 speed gearbox.
Best of both worlds, zippy off the mark and nice highway cruise rpm.
#7 Dave6179
Dave6179
  • 577 posts
  • Name:David
  • Car:HJ, VN, VX SS
Posted 12 March 2015 - 02:14 PM
Just remember, the taller the diff the worse in town/hills/towing/acceleration. As I did (and above) a 5 speed gives alround 'driveability'. A too tall diff can actually make fuel use worse.
#8 Bigfella237
Posted 12 March 2015 - 04:58 PM
I was looking at a manual trans from a VE Commodore and sixth gear has a ratio of 0.50:1, that means with a 285/30R18 tyre and even with a 4.11:1 diff, you'd still only be doing 1750 RPM at 100 km/h, damn that's tall!
Apparently manual VE Commodores typically have a 3.45:1 diff and HSV's have a 3.70:1
#9 _Macca97_
_Macca97_
Posted 12 March 2015 - 07:27 PM
sisters ve ute v6 190kw motor 6 speed has a 2:72 diff factory , in 6th you can put your foot to the floor and its like driving a red 6 with only 3 plug lead on, going up hill with the choke on and with half flat tyres, only time id ever use it would be doing 110 on the highway
#10 _Liam_
_Liam_
Posted 12 March 2015 - 08:53 PM
That is retarded, when you have OD gearbox you usually shorten diff gears not the other way around.
#11 S pack
  • 15,749 posts
Posted 12 March 2015 - 08:59 PM
Chasing better fuel economy no doubt.
#12 _Bomber Watson_
Posted 12 March 2015 - 09:12 PM
Yep those engines with there flash efi do dads and gizmo's and smart ecu's and shit lean the frOck out of the engine when she's at a steady cruise, hence all it can do is maintain a steady cruise, any slight incline puts it in a fit.
If you dont wear a skirt and have carbies and cams that actually open the valve and the like then you will find best fuel economy is actually not as low as you can get it, realistically a half decent street strip engine would probably get better fuel economy on the highway at 4200rpm (just a number out of my ass) than it would at 1200rpm.
Everyones needs are different though, i wouldnt try lugging a stock early Holden engine down below about 2200 on the highway.....
#13 Dave6179
Dave6179
  • 577 posts
  • Name:David
  • Car:HJ, VN, VX SS
Posted 14 March 2015 - 02:28 PM
Yep. My old stove hot 179 prefered a 3.9 diff over the 3.55, 3.36 and the 3.08. Economy and driveability got worse with the bigger diffs.
But, the 202 hated the 3.9, 3.55 in there now... and feels like it wants more, but 3.45 BW to go in soon.
#14 S pack
  • 15,749 posts
Posted 14 March 2015 - 06:37 PM
Not enough guts to pull the crust off a rice pudding with a 3.08 eh! :stirpot:
#15 axistr
axistr
  • 1,222 posts
Posted 15 March 2015 - 08:36 AM
With no overdrive gearbox 3.08 ratio would be my choice for all round driving. Depending on diff choice 3.55-3.45 if you rarely go on the highway & 3.7 or lower if you never go on the highway or don't want to drive at a constant speed more than 90kph.
#16 S pack
  • 15,749 posts
Posted 15 March 2015 - 08:42 AM
+1, but if you don't mind revving the ring off your engine at 100kmh then go for the lowest ratio you can find.
Edited by S pack, 15 March 2015 - 08:44 AM.
#17 _oldjohnno_
_oldjohnno_
Posted 15 March 2015 - 09:07 AM
I find overgeared cars to be irritating, and most modern production cars are overgeared. I think the engine needs to be into its usable rpm range at cruise. And as others have noted, sometimes mileage is improved by having the engine operate in its sweet spot - I had a 202 with 4.44 gears that gave surprisingly good mileage and was happy to cruise at 100 - 110km. At that speed the engine was into the lower end of its powerband and was perfectly happy.
#18 axistr
axistr
  • 1,222 posts
Posted 16 March 2015 - 08:29 AM
When choosing a final drive ratio it's always going to be a decision between specific use or compromise. If you have a specific use like only going in a straight line down the quarter mile the choice is much easier, go for a ratio that will see the engine rev to its maximum as it passes the finish line.
If your only going to use it for the highway go for gearing that will give you a low R.P.M at cruising speed 2.78 ratio or simular. But the compromise choice is a much harder decision.
The Torana is still a light car so I reckon for the average 308 engine with a four speed you can easily get away with a 3.08 ratio for every day cruising around in a variety of conditions. Many high performance engines don't like to drop to low in the rev range and get a bit harder to get of the line so I would go a bit lower ratio. Most high performance engines generally have a bad ignition curve when it comes to economy driving so as mentioned above the economy may not be very good with a high speed ratio.
That's where E.F.I comes into it, the best of both worlds as there are so many variables that the engine computer can adjust for.
Personally I like 6 speed overdrive boxes with final drive gearing of around 3.9-3.7 for street use. You don't have to use the overdrive gears around town if you don't want to, and than on the Hwy you have got an engine that can take it easy and all your money doesn't go out the exhaust.
What surprises me is my hatch 513hp & 502ft torque. Its running a 3.0-1 diff gears with a TKO Tremec with a .65 overdrive. The car had this diff ratio in it when I bought it and when I restored the car I was always going to change the gears for a set of 3.7 but never got around to it. When I take it to Toranafest each year its a round trip of 450km and uses 55-60 litres of fuel as the engines is only ticking over at 1,650 RPM. and because of the high torque output it still sinks you into the seat at 120kph.  Around town however I can easily use 50 litres just going to Parramatta and back a round trip of only 85km.
#19 Bigfella237
Posted 18 March 2015 - 08:46 AM
I thought I read somewhere recently that diff ratios in the high 3's were typically noisy?
Is that true only for 9" diffs, or only for a particular brand of gears? Is it limited to high 3's or would any low gearing, like say 4.11's, be noisy too?
Is it a case of the faster things spin the noisier they are or is it just a harmonics kind of thing with those particular ratios?
#20 _Bomber Watson_
Posted 18 March 2015 - 08:57 AM
Hmm considering the plethora of modern cars with ratios in that region that font make noise in going to assume they were installed wrong.
#21 Dave6179
Dave6179
  • 577 posts
  • Name:David
  • Car:HJ, VN, VX SS
Posted 18 March 2015 - 01:40 PM
A regular trip I used to make was 540km one way. Roughly half way I would top up. The std 3.55 and 5 speed would use $28 (yes, it was a long time ago... same car). With the 3.08 it then used $49, no other changes!. It would also do 165km/r in third@6000rpm. Nothing left in fourth. 3.55 it was still pulling in fourth at 5500 pushing 170, with more to go when into fifth. The 3.9 really woke up the 179 (186 +30) and would run out of gearing in fifth. But the economy was at its best.
#22 axistr
axistr
  • 1,222 posts
Posted 18 March 2015 - 06:27 PM
Bigfeller237 I think it has more to do with the brand and setting up of the gear set than the ratio. My 9" 3,0-1 makes no noise. Over the years I have has to redo many diffs and resets do to other people setting them up totally wrong.
Dave6179 Sound like your engine has a better ignition advance at mid range and maybe the vacuum advance isn't working properly. Or the carby in the lower range is running way to rich. Correctly set up ignition & fuel delivery will always produce better economy when the engine isn't working hard and generally at lower R.P.M
And so people wouldn't have a clue how to drive to economy.
#23 IMORAL
IMORAL
    Bored
  • 2,569 posts
  • Name:Paul
  • Car:LX SS HATCH - IMORAL
Posted 18 March 2015 - 10:19 PM
I ran 4:11's and had a period noise. Had it rebuilt with decent gears and it was good. Only a very very slight period noise but in the 4 region it is expected due to the tooth contact. Depending on how well it's built will depend how little the noise is as previously said.
