Recondition mag wheels
_RedSS_
Posted 21 March 2015 - 05:37 PM
I am wanting to recondition my cheviot mags and I got this reply from the last place I contacted after I sent them a pic.
"They look like they need shotblasting to remove old paint, then they'd need an epoxy primer and paint followed by CNC machining the face and finally clear coating. For all that you'd be looking around $250 a rim "
$250 a rim !!
No way there's got to be a cheaper alternative.
Anyone got any suggestions on a great way to recondition mags ?
_RedSS_
Posted 21 March 2015 - 06:07 PM
Posted 21 March 2015 - 07:44 PM
Umm, Sam where is the pic?
Posted 21 March 2015 - 07:49 PM
To me that sounds very reasonable for the amount of work involved from a company that is equipped to do it CORRECTLY.
Cheaper option is to do it yourself.
_duggan208_
Posted 21 March 2015 - 11:01 PM
Has anyone had any success with that bloody horrible clear coat. My AJS copies were only about 12 months old when the clear coat started doing some crappy things, these wheels were brand new.
regards
Posted 21 March 2015 - 11:35 PM
If its applied correctly it should last 10 years easy. 20 with some lovin.
Problem with the cheap chineese wheels you get for $100 each is every shortcut known to man kind is made.
Edited by Bomber Watson, 21 March 2015 - 11:36 PM.
_RedSS_
Posted 22 March 2015 - 12:01 AM
I really have to try and do something myself as $1000 is defiantly out for the wheels.
Any step by step suggestions of the best way to do it yourself ?
Would emery paper work on the face and rim to really cut it back ?, then maybe just repaint the inner part of wheel black and clear over the top?
Does anyone know much about the powerball or similar polish tool ?
Posted 22 March 2015 - 06:05 AM
Hi Sam,
I repaired a Hotwire once, where I had the dent in the rims edge aluminium welded in ( was free ),
then put an axle in the lathe, bolted on the Hotwire Mag, and machined both sides of the welded area,
until the dent and welding was smooth with the normal rims surfaces.
While I was there, the gutter rash got cut back ( machined off ).
Used emery-cloth on the machined area, to get the machining marks out,
and then with a bit more rpm, gave it a polish.
That is all I did.
_Agent 34_
Posted 22 March 2015 - 06:10 AM
Sam,
I have started a set for my race car and did this;
Started with 800
then 1200
then 2000
wet and dry.
put the polishing wheel on the drill then used paste and just worked it around.
The paint was reasonable so there was no need to re paint - plus there only for a race car - but came up quiet well and yes i was quoted between 250 to 500 per rim
you can by the posishing kits ( cloth wheel) off ebay and also super cheap.
If you use mothers aluminum polish (tub) rather than the bars that they supply then it's easier to work.
but you need to wet and dry the rim fist to cut all the anodized aluminum off the surface.
its a bugger of a job.
_LS1 Hatch_
Posted 22 March 2015 - 06:45 AM
Oven cleaner (with lye in it) also cuts through anodizing...
Posted 22 March 2015 - 08:00 AM
Having said that last time I did a set of Hot Wires that only needed the unpainted areas polishing on my old LJ, I just jacked it up (on jack stands) locked the hand brake on the passengers side (open diff), put it in drive (with front wheels chocked) & proceeded to use the drivers rear wheel to turn the mag whilst I polished (stationary hand). I used a foam backed wet & dry pads (same grits as Agent 34), but used kerosene as my lubricant as the polished results were a lot better than using water.... But be careful!! (I didn't have access to a lathe).
Edited by UC308Hatch, 22 March 2015 - 08:01 AM.
_Agent 34_
Posted 22 March 2015 - 07:29 PM
oxidized not anodized aluminum i ment to say.
Jell i have three to do so may give the oven cleaner a go next weekend.
G
Posted 23 March 2015 - 07:49 AM
Be careful using oven cleaners with caustic, it may make more work cleaning up the alloy than needed.
FWIW the last few wheels I have done I used paint stripper to remove the clear coat.
Tip; Polishing mag wheels is no diffedrent to polishing 2k paint.
_l31l31_
Posted 27 April 2015 - 09:49 PM
Hi would anyone have a set of old school Magnums 15x10 these a rare , but look great on a torana very popular in the late 70s and early 80s
Posted 05 May 2015 - 12:20 PM
Located an hour north of Sydney.
Shoot me a pm with pictures if your wheels and ill give you a quote
