You can use any polyester filler over the epotec.
So your regular bog, or a 2 part "knifing putty" like U-pol Dolphin glaze or Hot Shot.
I wouldn't recommend using the old acrylic "knifing putty"s to my worst enemy, once you try the 2 part stuff you will never go back.
For large areas scuff it, for filling pin holes or train tracks I just have the area scuffed. No need to hollow anything out.
Basically what i do once a car is in Epotec is go over it with the orbital with some 120, this quickly shows up where needs filling. Obviously I do ALL of my polyester work over epotec, no bog on bare metal.
As far as little train tracks and pin holes and the like go, these will show up as darker spots, just go ahead and wack the Hot shot/Dolphin glaze straight over them then block it back with a hard block and some 120-180.
Edited by Bomber Watson, 28 March 2015 - 07:02 PM.
