***245/50 R13 HELP has it been done?
13 wheel steel 245 Avon tub Sprintmaster
31 replies to this topic
#1 _Lctorana_
_Lctorana_
Posted 14 April 2015 - 10:32 PM
Want to stay 13"
Currently have sprintmaster's on the car looking to go steel with the chrome lip and came across the ZZS AVON road tyre it's a 245/50 R13. Im looking to have a steel set of 13's for the rear made to suit with offsets I need to fit, has anyone had or used these or a 235 on a 7x13" rim?
Looking to have 215 on front 245 rear if possible with out having to tub or massage the rear end
http://www.avonmotor...3924:image.jpg]
#2 _victor_
_victor_
Posted 15 April 2015 - 01:02 AM
You can put 235 on your sprintmaster's.
245 on 7" rims.
Victor
#3 yel327
  • 13,714 posts
Posted 15 April 2015 - 07:29 AM
I noticed they also have a 245/45/13
#4 hanra
  • 11,013 posts
Posted 15 April 2015 - 12:41 PM
I used to run 235/50/R13 SF-330 Eagers on all four corners of my TC Gemini many years ago. No flares. Just some el cheapo 13in mags.
#5 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 15 April 2015 - 12:48 PM
wonder how bad the fuel efficiency really is .was looking at them also yel327 sux ther'e for cars under 700 kgs
like the CR500s too would they be crap in dry as they have an A for for wet weather rating .
keen to purchase 2 of those
#6 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
Posted 15 April 2015 - 06:40 PM
I gave them a quick email earlier and christopher has mentioned to go the 55/215s for the 7j13 rim .i mentioned that ive had 235s on
the said rim and i know its pretty much as far as you can go but whats another 5mm each side.
my first choice was the ACB10 SPORTS tires but has advised against them as they are a crossply tire.hmm
he forgot to give me prices but will tomorrow i gather
#7 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
Posted 15 April 2015 - 07:26 PM
Gee he is super quik to reply . has advised to go an 8'' rim on the 245 because of the weight of vehicle.i just put 1100kg
also the zzs  are replacing the CR500's
prices for the  ZZS 215/55/R13   99 pounds lol
  120 pounds for the ZZS  245/50/R13.     HA HA
#8 _Lctorana_
_Lctorana_
Posted 17 April 2015 - 10:48 PM
madtoranajzedded I was hoping not to have to go to an 8" too so exactly what you said, whats an extra 5mm either side. if I get custom rim made up maybe il try for a 7 1/2" with the correct back spacing and roll the guards plus move the shock in I've been told it should all fit.
So AU $190 for 215's and $220 for the 245's
#9 _LS1 Hatch_
_LS1 Hatch_
Posted 18 April 2015 - 12:17 AM
I don't know of any one who makes a 7 1/2" steel outer, just keep in mind..
(and we supply a lot of the wheel companies there with outers)
#10 _Lctorana_
_Lctorana_
Posted 18 April 2015 - 12:23 PM
Oh I would have thought they could make up what ever size. Any things possible I've got a mate with a automated major pipeline welder/ cnc shop.
What is a set of inner/ outers worth jeff?
#11 _LS1 Hatch_
_LS1 Hatch_
Posted 18 April 2015 - 12:40 PM
Not sure what my mate has there in stock as far as 13" goes  (but no "in between sizes like a 7 1/2" though at least)...I can ring on Monday and check if you like.  (15" stuff is most common and we do most sizes and styles in them, some in 14" and 16" as well..)
They are rolled steel and come in certain sizes. You could cut and shut them I suppose if you like but we don't sell anything like that.
Oh, and what did you mean by inners ?
We only do the outers themselves, no centers in 13"...the shops (wholesale that is) pretty much supply them or are just cutting out centers from customers wheels to widen, etc.
(He has 15" centers for chev rally and smoothies though.)
#12 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 18 April 2015 - 04:31 PM
Most wheel repair mobs are more than able to do a custom width, provided they only have to make one continious weld.
#13 _Bomber Watson_
Posted 18 April 2015 - 05:43 PM
Yes but your also paying an extra hour or two's labour ontop of the cost of the rim, instead of just the cost of the rim, per wheel for something which is really pretty pointless.
#14 _Lctorana_
_Lctorana_
Posted 18 April 2015 - 09:59 PM
Bomber is back! Haha yeh I'd say more than likely just go for a stock 7" Then.
I also found kumho do a 235/45 r13V70A series tyre, anyone used or heard anything about them there's not a lot of info or reviews
Sorry Jeff by 'Inners' i mean centres, I'm not in California but would be good to know what sort of dollars are involved in getting a set made so would be great if you could find out. Well appreciated
#15 _LS1 Hatch_
_LS1 Hatch_
Posted 19 April 2015 - 01:45 AM
The outers are there...not here anyways, so no fuss! And as mentioned, don't send over any centers that small, just the 15" stuff pretty much. :)
#16 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 19 April 2015 - 03:46 PM
I am well aware that it virtually doubles the price of the job, but if an oddball size is really needed, it can be done.
#17 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
Posted 20 April 2015 - 01:36 AM
Hi Dj can you give me a run down why i shouldnt just buy the 245s as its only 5-6 mmm more ea side.
is the lower profile the prob.
if its just the weight that dude is worried about whats it going to do.blow off rim.uneven wear etc
#18 _Bomber Watson_
Posted 20 April 2015 - 08:44 AM
They would look pretty baggy and crap on a 7" rim.
#19 _LS1 Hatch_
_LS1 Hatch_
Posted 20 April 2015 - 11:09 AM
The only 13" outers my mate keeps there is 13" x 7" and they are $50 each, if you were wondering. :)
(He's there in Lilydale)
#20 _Lctorana_
_Lctorana_
Posted 20 April 2015 - 02:43 PM
Ohh even better jeff that's just around the corner! Thanks for the help you you have a number I can contact him on? Or business name
#21 _LS1 Hatch_
_LS1 Hatch_
Posted 20 April 2015 - 02:55 PM
It's 97376330.. (Mr Lugnut is the company, on Beresford Rd) just talk to Luke and tell him I mentioned about them to you and all. :spoton:
(Normally only deals in wholesale quantities but I mentioned to him you were looking,etc so no problem!)
#22 _Lctorana_
_Lctorana_
Posted 20 April 2015 - 06:12 PM
Jeff really appreciate that! That will help a lot :)
#23 _Bomber Watson_
Posted 20 April 2015 - 08:51 PM
If you go a 7" rim I really think a 225 would be more suitable.
Thats what I run on the back of mine on a 7" rim, tyre sits about perfect on the rim, and because the cars are so small they do look fairly big.
I had 245's on a 7" rim in a previous life and I didnt think it looked that good then, Nowdays im ashamed to admit it. They looked like frOcking steam rollers under the back.
#24 _Lctorana_
_Lctorana_
Posted 20 April 2015 - 11:29 PM
Bomber do you have any pictures of the 245's on it?! Would be good to see what it would look like if I went that direction.
And what brand tyre do you run with a 225?
#25 _LS1 Hatch_
_LS1 Hatch_
Posted 20 April 2015 - 11:46 PM
Glad to be able to help!
Also tagged with one or more of these keywords: 13, wheel, steel, 245, Avon, tub, Sprintmaster
