Hi everyone,
Can anyone from WA tell me if the pits will pass stainless braided fuel line from the tank to the engine or does it have to be a solid line.
And if you can what size line would be recommended.
Thanks guys.
Posted 04 May 2015 - 10:00 PM
Hi everyone,
Thanks guys.
Posted 05 May 2015 - 12:03 AM
Just don't go drag racing with it
ANDRA
Posted 05 May 2015 - 07:10 AM
Posted 05 May 2015 - 08:40 AM
Posted 05 May 2015 - 09:21 AM
found this Craig:-
Thanks mate, that helps heaps
Beware of braided hoses contacting the back of the alternator.
Sure will thanks bud
Posted 05 May 2015 - 09:25 AM
ANDRA
4.1.8.2 Fuel SystemsWhen permitted, fuel tanks and fuel lines should be located ahead of the engine. Fuel blocks, if used, must be mounted at least150mm (6 inches) forward of the flywheel/bell-housing area. Fuel lines in the flywheel/bell-housing area must be enclosed in a400mm (16 inch) length of steel tubing 3mm (1/8 inch) inch minimum thickness, securely mounted as a protection against fuellines being severed, or be re-routed outside the chassis or frame rails. This requirement is waived for vehicles fitted with either asteel flywheel and pressure plate or a scattershield. Where fuel lines pass supercharger drive areas they should be encased inprotective steel tubing or braid. Fuel tanks located in front of grille and out of the protective areas of the body, frame and wheelsmust be protected against collision damage. All mechanically fuel injected vehicles, or any vehicle using a pressurised fuel tankmust have a quick-action fuel shut-off within easy reach of the Driver/Rider, operating on the main fuel line between the pumpand the injectors. Under no conditions, except where permitted by class regulations, are any fuel tanks, lines, fuel pressuregauges or other units containing fuel permitted in the driver’s compartment. All tanks must be completely isolated from thedriver’s compartment by a firewall, completely sealed so as to prevent any fuel from entering. Where the fuel tank is located infront of the driver and engine is in rear (rear engine dragsters) fuel lines must be isolated from the driver’s compartment with asub floor or by the use of steel braided lines. All vehicles where a fuel line passes the driver must be fitted with metal fuel linesexcept for a maximum of 300mm (12 inch) of approved flexible hose to allow connection at the tank or pump. The metal fuel linemust carry at and Kevlar lines may be used in lieu of solid metal lines. In all cases, fuel lines must be of suitable construction,designated as fit for purpose by the manufacturer.
Wont be going that far, but interesting read, Thanks Datto
Mine went over the pits with rubber fuel line , it just has to be rated for fuel
Thats great mate, did you have a electric fuel pump or standard
Posted 05 May 2015 - 10:37 AM
Electric mounted under car between diff and tank
Edited by mumbo, 05 May 2015 - 10:38 AM.
Posted 05 May 2015 - 11:08 AM
Awsome, thanks mate
