cam selection advice
94 replies to this topic
#1 _D Train_
_D Train_
Posted 11 June 2015 - 09:52 PM
I've got my engine out for a bit of a freshen up 308 red motor.
I'm changing to vn heads (reconditioned) with new intake and exhaust.
Whats the biggest cam i could run with standard push rods and rockers?
Ive been looking at the crane packages on ebay
I was leaning towards the 286. Any tips would be appreciated.
#2 N/A-PWR
  • 9,595 posts
Posted 11 June 2015 - 10:17 PM
Hi there D Train,
As the Cam get's bigger, the RMP range goes higher,
so when you look at a CAM rpm lIst, you can then gauge your max rpm.
On top of that, will be the idle circumstances, where an Auto is concerned.  B)
#3 _D Train_
_D Train_
Posted 11 June 2015 - 10:21 PM
Cheers dave.
She is m21 and 3.08 (banjo)
The cam i pulled out was a 276 crane
#4 Ice
  • 15,127 posts
Posted 11 June 2015 - 10:26 PM
You could go even one bigger if you wanted to since you have an M21
#5 N/A-PWR
  • 9,595 posts
Posted 11 June 2015 - 10:34 PM
http://www.cranecams...heet_9-9-10.pdf
The CC272 looks good:-
Mechanical
2800-6500
1/2" valve lift
112 lobe separation for idle quality
#6 _D Train_
_D Train_
Posted 11 June 2015 - 10:48 PM
May have to switch to roller rockers
#7 N/A-PWR
  • 9,595 posts
Posted 11 June 2015 - 10:54 PM
Solid lifter cam's are good.
Roller lifter cams are after that, which are called roller cams.
You can still have standard tappets, with a solid cam, I have done in the past, no worries.  :D
#8 _ljxu1torana_
_ljxu1torana_
Posted 11 June 2015 - 11:11 PM
crane cc300 is the way to go for a big performance cam.
#9 _D Train_
_D Train_
Posted 11 June 2015 - 11:17 PM
Might be a bit wild for the rest of my combo. My bottom end is fairly standard
#10 _D Train_
_D Train_
Posted 11 June 2015 - 11:20 PM
The h284 is more along the lines of where im headed.
Still trying to use my old rockers and pushrods
#11 N/A-PWR
  • 9,595 posts
Posted 11 June 2015 - 11:27 PM
Standard bottom ends, can take a hiding IMHO,
So it is a learning curve to see how far you can go.
The Cam I selected up there^^^, is good, where you don't have to rev it to the max, if you don't want,
but when you do, she will wear out the standard bottom end.  :furious:
In my years, I wear Red6 ones out in 4000 km's @ 7500 rpm for the first gear take offs,
Excellent Choice Mate.  :clap:  :spoton:
#12 Ice
  • 15,127 posts
Posted 11 June 2015 - 11:32 PM
That would be fine
#13 _D Train_
_D Train_
Posted 12 June 2015 - 08:32 AM
Progress shot
Edited by D Train, 12 June 2015 - 08:39 AM.
#14 _D Train_
_D Train_
Posted 12 June 2015 - 08:11 PM
http://pages.ebay.co...2848540&alt=web
this is the kit i am looking at
#15 N/A-PWR
  • 9,595 posts
Posted 12 June 2015 - 08:19 PM
Nice Package:-
HYDRAULIC - Fair idle, strong mid range - top end street & strip performance. Needs 9.5-10:1 comp 3.08-3.5 gears, Hi-stall converter etc. for best results.
BASIC RPM 2200-6000
PowerMax H286
244621
230
230
292
292
110
.496
.496
Going to be a goodie.  :D
#16 _D Train_
_D Train_
Posted 12 June 2015 - 08:44 PM
Cheers dave. I toned it down a little and went for the h284. I just put my order in now, will still be more agressive than the one i pulled out. Now just gotta wait for em to show up.
Block is at the engine shop getting honed. Exciting times!
#17 N/A-PWR
  • 9,595 posts
Posted 12 June 2015 - 09:09 PM
You know your stuff Mate,
See what happens next.  :3gears:
#18 _D Train_
_D Train_
Posted 26 June 2015 - 09:22 AM
Everything back from the engine shop, block honed vn heads recon crank polished.... assembly time!!
This is actually my first rebuild, ive been asking lots of questions and watching video clips but if anyone has any little tips to shout out I will be all ears!
#19 LC-GTR-1969
LC-GTR-1969
    Shed tinkerer
  • 1,162 posts
  • Car:Which one?
Posted 26 June 2015 - 10:38 AM
Few quick tips...
1) Mare sure you scrub the cylinders very well with soapy water to remove and hone grit. Do not assume this has been done.
2) Make sure you check 'end' float of the crank- most just install thrust bearings and neglect to actually check the float. Lever the crank in each direction and check the amount of play. Dial indicator is the correct way but you can get away with feeler gauges.
3) Check bearing clearances with plasti-guage. Make sure you have holes for bearings installed/aligned with oil holes (have seen these wrong many times leading to dry running, and subsequent failure by spinning a bearing).
4) I use engine assembly grease to prevent dry start up- many dont but hey, new engine I like to protect it. Cover bearing shells and cam lobes.
5) Torque bolts in stages, and oil the bolts to prevent false readings with torque wrench.
6) When installing cam- make sure you degree it! Use a degree wheel 1) The cam need to be checked that the valve timing events occur as per the cam card. This is for two reasons, a) that the cam was ground correctly and B) that the woodruff key on the gear is aligned correctly. You may need to modify a new offsett key if issues occur- there are a few tricks if the timing is off by a little.
7) Prime the oil pump before assembly
There is heaps more but these are the common issues... Ring end gap needs to be checked, as does alignment of the end gaps... Also, when tightening the main bearings, keep checking that the crank spins freely without binding. If it binds you probably have your bearing order mixed up or back to front. Or the clearances are too tight.
If I think of more I will let you know...
#20 N/A-PWR
  • 9,595 posts
Posted 26 June 2015 - 10:59 AM
Great information as usual J,
Like button for you.
#21 _D Train_
_D Train_
Posted 26 June 2015 - 11:14 AM
Cheers mate there some great tips. I'll be taking them all aboard.
#22 _D Train_
_D Train_
Posted 26 June 2015 - 11:27 AM
Just got it dummied up for some paintAttached File  2015-06-26 09.25.36.jpg   380.91K   1 downloads
#23 _D Train_
_D Train_
Posted 25 July 2015 - 07:54 PM
Finally after a bit of a break away and a few distractions i managed to get some engine assembly done. Probably another day left for the install. Hopefully fire her up by monday!!
#24 _Bomber Watson_
Posted 25 July 2015 - 07:59 PM
Good to see you used your brain and went from gilmer back to V belts.
#25 _D Train_
_D Train_
Posted 25 July 2015 - 08:16 PM
Not a fan of gilmer drives??
