thermo fans better at front or back of radiator
48 replies to this topic
#1 _lc6gtr_
_lc6gtr_
Posted 21 June 2015 - 05:16 PM
just a quick question about to install 2 10" thermo fans to my torana lc  its just a 6cyl now  am i better putting them at the front of the radiator between engine or front off the car or it dosnt make a diffrents
#2 BIG KEV
BIG KEV
  • 1,218 posts
  • Name:Kevin
Posted 21 June 2015 - 05:30 PM
I would think space/room would play a bit part on where you mount them
#3 Dave6179
Dave6179
  • 577 posts
  • Name:David
  • Car:HJ, VN, VX SS
Posted 21 June 2015 - 05:35 PM
If you have cooling issues, at the rear will be best. Blocking air flow is the worst 'fix'. Have you tried a 160 degree thermostat? I did, went from a 182 unit with better than expected results. Even found some horses.
#4 _lc6gtr_
_lc6gtr_
Posted 21 June 2015 - 05:51 PM
i can fit between engine i ready checked will be swaping my therno stad  for a 160 degree but want the fans in still just trying to workout were best to fit them
#5 Dave6179
Dave6179
  • 577 posts
  • Name:David
  • Car:HJ, VN, VX SS
Posted 21 June 2015 - 06:51 PM
I'm using a Flexolite fan. Loads less drag than std, tried lectric years ago... not worth the effort.
#6 IMORAL
IMORAL
    Bored
  • 2,569 posts
  • Name:Paul
  • Car:LX SS HATCH - IMORAL
Posted 21 June 2015 - 06:53 PM
Useless at tits on a bull in the front regardless of your combo. Must be at the back or your wasting your time
#7 _Mint_
_Mint_
Posted 21 June 2015 - 07:34 PM
yep I prefer them behind the radiator I used to have a single electric fan but now 2 hi flow ones with a shroud best thing I ever did even on 35+ deg days it doesnt get hot
#8 IMORAL
IMORAL
    Bored
  • 2,569 posts
  • Name:Paul
Posted 21 June 2015 - 07:39 PM
yep I prefer them behind the radiator I used to have a single electric fan but now 2 hi flow ones with a shroud best thing I ever did even on 35+ deg days it doesnt get hotfans001_zps6ab20f99.jpg
Must be good fans to keep it cool with one not Plugged in :stirpot:
#9 _Mint_
_Mint_
Posted 21 June 2015 - 07:51 PM
lol..both not plugged in Paulie that pic was right after I put em in
#10 IMORAL
IMORAL
    Bored
  • 2,569 posts
  • Name:Paul
Posted 21 June 2015 - 07:53 PM
Very nice Tim. Everything looks so clean and new!
#11 StephenSLR
StephenSLR
  • 6,715 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 23 June 2015 - 11:10 AM
Not only do you have to reverse the polarity of the motor to spin the right way but if you didn't flip the fans over so the vanes push the air the right way; then yes it would be useless.
You can mount them in front or behind.
s
Edited by StephenSLR, 23 June 2015 - 11:11 AM.
#12 IMORAL
IMORAL
    Bored
  • 2,569 posts
  • Name:Paul
Posted 23 June 2015 - 11:43 AM
They block the air flow even if connected correctly. When driving on the highway with the correct size radiator you shouldn't need the fans on. Yes they will work but they reduce the efficiency of the radiator if they are in front. That being said each to their own. I personally wont run them in front.
#13 TerrA LX
Posted 23 June 2015 - 11:45 AM
Just like the A9X factory set up?
Useless?
#14 StephenSLR
StephenSLR
  • 6,715 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 23 June 2015 - 11:58 AM
It doesn't work like that, placing something behind the radiator also blocks air flow; air needs to flow freely from in front and behind.
I imagine the only advantage of having them behind is if you have a square shroud that covers all four corners; a fan and shroud behind will draw air from the corners more efficiently than if you have the same fan and shroud in front trying to push air to all four corners.
s
Edited by StephenSLR, 23 June 2015 - 12:01 PM.
#15 IMORAL
IMORAL
    Bored
  • 2,569 posts
  • Name:Paul
Posted 23 June 2015 - 01:28 PM
ok run them in the front then :surrenderwave: I wont be :)
Yes agreed. The ones I was referring too have flaps that open while driving to allow air flow through the shroud. They stay closed while stopped allowing the fans to draw the making cfm they are capable of through the radiator.  All I know in my current set up on a car I just purchased is crap and I will guarantee when I fit these to the rear of the radiator I wont have any heating issues.
#16 StephenSLR
StephenSLR
  • 6,715 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 23 June 2015 - 01:49 PM
ok run them in the front then, I wont be :)
I'm not telling anyone how they should run their set up. I have a 16" behind my radiator; it won't fit in front even if I wanted it to.
I'm just saying that running one in front is not "useless as tits on a bull".
If you're having cooling issues there's probably more to it than fan location.
A 16" fan it pulls more cfm than 2 x 14" so you may want to consider a 16". I have one behind a triple core radiator cooling a mildly worked 308 and the needle usually sits around 1/4 or a little past and has never been half way. Of course when I switch off the engine after a long drive then start it up soon after the needle goes to around 3/4 but the fan switches on and cools it down again.
s
Edited by StephenSLR, 23 June 2015 - 01:51 PM.
#17 IMORAL
IMORAL
    Bored
  • 2,569 posts
  • Name:Paul
Posted 23 June 2015 - 02:15 PM
Yeah agree. I am going with a twin fan that pulls 2750 cfm. I am aware of the 16" singles.  A mate runs one and its over the 3000cfm mark but setting in up in a shroud with my set up is a bit of a pain due to the radiator size. Current fan is a single thermo in no shroud which is useless. The fans are the issue because it sits on 80deg when on the highway getting the air flow. As soon as I come into some traffic up the temp goes. The single fan I have just isn't up too the task. I think its just a cheap and nasty as there are plenty of singles that pull decent cfm. This isn't in a torana either.
#18 StephenSLR
StephenSLR
  • 6,715 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 23 June 2015 - 02:32 PM
I hear with a shroud you sit the fan 2/3 in the shroud. Some sit the fan half in/half out. You don't sit the fan fully in the shroud as the fan itself reduces the volume within the shroud and obstructs air flow. You want to have that 'cone' of shroud volume in front of the fan.
My 16" doesn't have a proper shroud that extends to all corners of the radiator but it does cover most of the core area and the frame that it sits within is closed around the side perimeter which in a way is a bit of a shroud itself. I hear the smaller ones don't have this? I remember seeing a twin set up and they basically had nothing enclosing the fans, just a flimsy frame that they sat on but I guess they worked enough to keep the car cool.
s
#19 EunUCh
EunUCh
  • 2,774 posts
  • Car:japos
Posted 23 June 2015 - 06:06 PM
:unsure: ....probably the easiest way is fit a gilmer drive pulley to the snout of the crank and run a belt to an intermediate shaft mounted
somewhere on the front rail or splash guard  to poke through the radiator support panel then run another gilmer belt to
a spindle mounted up front somewhere that holds the the fan...
But seriously :)...most of the OEM stuff has the thermos. on the engine side of the radiator,there must be a reason for this?
The fan will be a restriction no matter what,easy test,grab a fan and push it through the air as fast as you can by hand,there will
be a drag,if mounted on the front the first thing the fan "sees" is whatever air speed is being driven at it because it is first in line and whatever gets through it  then "sees" the radiator?
If it is mounted engine side it will "see" what is left of the air speed that has passed through the radiator before reaching the fan and hopefully picked up some heat on the way?
#20 StephenSLR
StephenSLR
  • 6,715 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 23 June 2015 - 06:16 PM
But seriously :)...most of the OEM stuff has the thermos on the engine side of the radiator, there must be a reason for this?
Do you have a reference to what percentage of OEM stuff has the thermos on the engine side of the radiator?  I've seen them on both sides and I'd say it comes down to whatever is more convenient in manufacture and assembly.
s
#21 StephenSLR
StephenSLR
  • 6,715 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 23 June 2015 - 06:35 PM
Push vs. pull is pretty much the same but there is one argument for having the fan behind in pull configuration.
It's harder to clean the bugs out of the front of the radiator when you have a fan in front of it.
:lol:
s
Edited by StephenSLR, 23 June 2015 - 06:37 PM.
#22 EunUCh
EunUCh
  • 2,774 posts
  • Car:japos
Posted 23 June 2015 - 06:53 PM
No...no % reference on which way who uses what config.  .. just going on what Holden and Ford used over the years that seemed to
work...on a rough scale... VN-VT...engine side :)
#23 _Mint_
_Mint_
Posted 23 June 2015 - 08:14 PM
yep I agree Paulie..this is exactly what I had but one of the smaller hi flow fans I have now out flows the larger single I had before so now I have maybe 3 times the cfm plus a shroud
also running twin fans usually gives you a "valley" between the 2 which helps for clearance from water pump pulleys etc
I have seen a single fan mounted in front of the radiator on a drag car so when it sat in pits they had it running with an electric water pump to cool the motor between runs but this was a drag car
#24 N/A-PWR
  • 9,644 posts
Posted 23 June 2015 - 08:23 PM
I did well with this Fan on the fully worked 6:-
Flex-a-Lite-Belt-Driven-Fans-Low-Profile
When revving the ring out of the motor, the blades flex straightish  :D ,
coupled with the triple core HQ radiator, no problems.  :spoton:
80 miles an hour non-stop.
They do crack over Time, so check.
#25 Ice
  • 15,214 posts
Posted 23 June 2015 - 08:31 PM
And they go thru bonnets to Dave when they let go
