Kelpro bushes vs Mackay bushes
7 replies to this topic
#1 jd lj
jd lj
  • 2,120 posts
  • Name:James D
  • Car:LJ
Posted 24 June 2015 - 05:26 PM
Hi guys,
I recently purchased a pair of bushes for my trailing arms and the only ones available locally seems to be manufactured by Kelpro.
I've used Mackay bushes in the past and have been happy with the result. The first difference I noticed about the kelpro bushes compared to the Mackay ones is the the inner steel tube protrudes probably about 5mm past the rubber. On the Mackay bushes the rubber finishes pretty much flush with the inner tube.
My thoughts are that the Mackay bushes would possibly have better support if there was any sort of sideways leverage or twisting. What do you guys think?
Has anyone had any experience with the kelpro trailing arm bushes, good or bad? I'd like to know if they're worth using or if I should return them and avoid any problems and track down some Mackay bushes instead.
Thanks JD
#2 dattoman
  • 16,490 posts
Posted 24 June 2015 - 08:22 PM
Mackay make the bushes currently sold by Holden as genuine bushes
Tiny has Kelpro bushes in his Monaro
Removed the Nolathane and says its the best thing he ever did
#3 axistr
axistr
  • 1,224 posts
Posted 25 June 2015 - 11:19 AM
I give up on plastic style bushes years ago. Never had a good run out of them due to splitting after about 5,000 km. I use Mackay rubber bushes in my vehicles.
#4 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 08 July 2015 - 10:34 PM
i just got my Mackay rubbers from rares and  i am sending them back.look very poorly made.one crush tube isnt centred and rubber appears to have been pressed or whatever they do any old way.
will be getting kelpro
#5 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
Posted 09 July 2015 - 07:39 PM
I have just talked to Edan on the rubbers and the culprit was that i had the old stock mackay which to me are poorly made
Rares have since changed and remade them themselves, i have seen pics of the new ones and i'm happy to say very pleased with what iv'e seen .
so  sorry if iv'e given anyone any reason not to purchase  their new rubbers .
cheers Maz
Edited by madtoranajzedded, 09 July 2015 - 07:41 PM.
#6 jd lj
jd lj
  • 2,120 posts
  • Name:James D
  • Car:LJ
Posted 10 July 2015 - 08:00 PM
I got hold of some Mackay bushes which I'm now happy to have as their products are more like the original holden items than the other ones I had from kelpro. The kelpro bushes are probably fine once installed but I personally prefer the Mackay bushes myself.
#7 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
Posted 11 July 2015 - 01:15 AM
The ones i got James the rolled tube protuded out some flat and a couple in further than rubber and also tube wasnt  rolled nice and round.
these were dated 5th 2013. i must of got a bad batch.
#8 jd lj
jd lj
  • 2,120 posts
  • Name:James D
  • Car:LJ
Posted 11 July 2015 - 08:02 AM
The first time I saw these I was surprised that the inner tube was rolled and not made out of a section of steel tube, you'd think using a section of tube would be easier than rolling a flat plate.
