Which Radiator?
_rawdog_
Posted 25 June 2015 - 05:32 PM
Posted 25 June 2015 - 05:39 PM
I think Adrad/Natra still make cores for these in South Australia. I'd talk to them and see what they can do. You may still be able to get a high density (HD) radiator core with fins closer together.
Posted 25 June 2015 - 05:58 PM
Hi there Mark,
Those symptoms of yours,
are the same I had with the same worked 208,
living in Sydney at the time, stuck in traffic was a panic.
So after a few years, I stumbled across a Radiator guy,
who said, why don't you try a triple core v8 radiator with HQ top and bottom tanks,
as the water in and outlets are the same as the little Six.
So I said, I will give it a go, and $330 bucks later back then in 1990,
I never looked back.
Best thing ever, can now do what ever we like and never gets HOT.
Posted 25 June 2015 - 06:00 PM
I have recently converted my LC from a 138 to a worked 202 60thou over.
is there a better option??
Posted 25 June 2015 - 06:16 PM
Posted 25 June 2015 - 06:28 PM
No they are not.
The 350 Chev fitted HQ holden had a radiator that is very similar to the Holden 6 fittings.
You could also buy a kit, thru NATRAD that had all new parts, 3 core, wide side bands, top and bottom tank and fittings, that had to be assembled.
this could be bought in 6 and 8 configurations.
Posted 25 June 2015 - 06:31 PM
Sorry to waste your time,
Back to the drawing board here.
Posted 25 June 2015 - 06:33 PM
may have been that he could put the little six tanks onto the HQ triple core Radiator
something happened down that line, and worked.
Posted 25 June 2015 - 06:44 PM
Found this sold one:-
Aussie desert cooler radiator to suit hk ht hg. 4 core triple pass
http://www.gumtree.c...ator/1076966140
Just right for the Little Six in and outlets
Edit:-
So what top and bottom tanks are on that Quad Core, anyone?
Edited by NA-PWR, 25 June 2015 - 06:57 PM.
_Macca97_
Posted 25 June 2015 - 07:08 PM
they've just got dividers in the tanks dave, abit like the vl's with the rb motors
Posted 25 June 2015 - 07:29 PM
HJ-HZ 6cyl with A/C or HD radiator had the same 3 row as a V8 with A/C, just with 6cyl outlets. This is the one I have always used with a SBC, just move the bottom outlet to the top and put a big one on the bottom. You can put an Aussie made 4 row Natra core in these. Not sure if they fit an LC though, but they fit LH-UC if you trim the rear shroud mount.
_hutch_
Posted 25 June 2015 - 07:36 PM
It never hot running at around half scale on the gauge,engine is a worked 202 bored 60 thou,I live in mildura with summer temps around 45 so it works cost me $400
_rawdog_
Posted 25 June 2015 - 08:22 PM
_hutch_
Posted 25 June 2015 - 08:33 PM
_rawdog_
Posted 25 June 2015 - 08:36 PM
Thanks Hutch. Who did your radiator rebuild to 3 core?
_hutch_
Posted 25 June 2015 - 08:38 PM
Mildurs City Radiators here in Mildura,was around Christmas i think or just after
I might add that this guy does all our gear from work and i have known him for years so exactly what it should cost i don't know,core was from NATRAD
Edited by hutch, 25 June 2015 - 08:41 PM.
_rawdog_
Posted 25 June 2015 - 09:09 PM
i had a 192 in my HK years ago did everything to the bloody thing................still ran at 200 all day summer winter or when ever
