Hz/wb brake calliper kit problems
Posted 02 July 2015 - 11:30 AM
Posted 02 July 2015 - 03:11 PM
Posted 04 July 2015 - 08:35 AM
Posted 04 July 2015 - 11:46 AM
What caliper kits did you buy ?
Posted 04 July 2015 - 05:06 PM
I had the same problem.......don't laugh I found the solution at Bunnings in the garden / water irrigation section. It is a Toro hose joiner which has the exact Inside & outside diameter of the caliper slide pin that is supposed to be insulated.
Has been ok for more than a year...............
P1060960.JPG 79.19K
3 downloads
Posted 06 July 2015 - 04:09 PM
The kit is K1367S and piston is db2749
Posted 06 July 2015 - 04:11 PM
If i cant get anything else i will be going with this cheersI had the same problem.......don't laugh I found the solution at Bunnings in the garden / water irrigation section. It is a Toro hose joiner which has the exact Inside & outside diameter of the caliper slide pin that is supposed to be insulated.
Posted 06 July 2015 - 08:28 PM
Right kits
They must have deleted the sleeve
We used to have loose rubber for the job years ago... but all gone
Posted 06 July 2015 - 09:10 PM
Cheers for that looks like the garden hose wins. I might check out clark rubber as well.Right kits
Thanks for all the help
