Just wondering who manufactured the crown wheel & pinion for the banjo?
Did Borg Warner make crown wheel and pinion to suit the banjo diff?
Is part #7438806 a compatible 3:36 gear set for a banjo diff?
Posted 06 July 2015 - 10:44 PM
Posted 06 July 2015 - 11:14 PM
Part #7438806 is a 3:36 gear set for a banjo diff.
Posted 06 July 2015 - 11:25 PM
Thanks Dave
Posted 07 July 2015 - 07:20 AM
Borg Warner made the LSD 2.78:1 (V8 only at that time and the only diff you could get behind a 307) for HK, not sure if that is just the LSD hemi or if they did the gears too. I have seen the driveline section of the HK Engineering Technical Manual that actually shows the applicable driveline combos and it makes a comment along the lines of "when GMH starts manufacture of the 2.78 and 3.08 rear axle centres that both 2.78 and 3.08 will be available in non-LSD". So i'm not sure at what stage GMH started making these LSD centres or if they ever did. Non-LSD V8 banjo in HK are very rare, Dr Terry told me he had seen some over the years but I don't know of anyone else who has.
