Intermittent Wiper for LX
28 replies to this topic
#1 _sunburst73-xu1_
_sunburst73-xu1_
Posted 08 July 2015 - 06:53 PM
This may or may not have been covered before but can you and if so how easy is it to convert an LX Torana to have intermittent wipers?
What unit would be best to use.
Any feedback would be appreciated.
cheers Dane
#2 Statler
  • 6,332 posts
Posted 08 July 2015 - 10:46 PM
You could use a UC item.
The dwell knob would need to be put somewhere though.
#3 _sunburst73-xu1_
_sunburst73-xu1_
Posted 09 July 2015 - 06:25 AM
Thanks Col, I didn't know that UC's had them.
Edited by sunburst73-xu1, 09 July 2015 - 06:27 AM.
#4 Statler
  • 6,332 posts
Posted 09 July 2015 - 08:49 AM
Look for an SL/E.
#5 axistr
axistr
  • 1,224 posts
Posted 09 July 2015 - 08:51 AM
I used the UC setup in mine easy to install if you have a basic understanding of wiring. Bosh also do a universal dwell unit but they are starting to get a bit harder to buy new. I hooked up mine through the high speed wiper circuit.
#6 SS hatch
SS hatch
  • 104 posts
Posted 09 July 2015 - 09:29 AM
I've used a dunnydore blinker stalk with dwell switch  setup from same model vb- vk with a couple of relays. Works fine with standard motor.From memory I have a sle uc switch and had dramas so went the vb setup.
Edited by SS hatch, 09 July 2015 - 09:37 AM.
#7 _sstorana_
_sstorana_
Posted 09 July 2015 - 03:09 PM
Dane,
UC one will plug straight in. Just need to relocate the Dwell knob. (if you're not running a choke, you can use the choke hole.
Mick
#8 EunUCh
EunUCh
  • 2,774 posts
  • Car:japos
Posted 09 July 2015 - 05:29 PM
After reading much around here about the blinker/ind. stalks ect. i got the impression that LH had a foot operated hi/lo beam switch with wiper switch on the dash?whereas the LX had hi/lo beam on the stalk with the wiper switch on the dash ?, the the mighty UC had wipers and hi/lo beam on the stalk.
Then i had a look at the plugs of the switch gear in coffee pot to main harness from LH,LX,UC,como.(unsure of model como, but the como. setup had a different plug from the rest) , and the pinouts  from LH/X/UC to main harness were all different ?
easier just to make up or buy an intermittent wiper gizmo and wire it in to the existing circuit with a dwell control in an unused spot somewhere handy with the right switch gear to make it work in both int. and "normal" modes.
#9 _hutch_
_hutch_
Posted 09 July 2015 - 07:10 PM
Years ago you could buy an aftermarket unit,it had a control box with a small knob on the front,biggest job was mounting the box itself,connections whas an ign feed,earth and a wire to the low speed at the switch,it worked buy pulsing the low speed simple as
#10 Bigfella237
Posted 09 July 2015 - 08:50 PM
Is a Torana wiper motor a "self parking" type?
If so there is the Hella 7010 kit and the knob even looks like it might suit an LX too...
$160 on the OzAutoElectrics website.
#11 rodomo
  • 18,062 posts
Posted 09 July 2015 - 09:16 PM
Look for an SL/E.
This is UC SL/E
#12 EunUCh
EunUCh
  • 2,774 posts
  • Car:japos
Posted 09 July 2015 - 10:10 PM
from the top
LH/LX/uc plugy things to main harness from the top end.
Attached File  plguc.JPG   173.23K   8 downloads
sl/e looks a bit to upmarket for something from GMH...what were they thinking :)
#13 rodomo
  • 18,062 posts
Posted 09 July 2015 - 11:05 PM
UC's were the transition Holden from Torana to Commodore.................Unique vehicle.
#14 76lxhatch
  • 7,222 posts
Posted 10 July 2015 - 06:24 AM
I would assume the UC unit should be just that anyway, early Commodore (e.g. VK) are definitely stand alone (aside from wiring to the wiper motor of course) and work fine
#15 _sstorana_
_sstorana_
Posted 10 July 2015 - 09:31 AM
When you splice the UC Intermittent Wiper control into the LX Wiper set up, it doesn't go anywhere near the steering column Harness..
#16 Pop's-SS
Pop's-SS
    Pops
  • 4,971 posts
  • Name:Barry
Posted 10 July 2015 - 12:46 PM
That dwell housing ran a bell in my old feeble brain and I have one or two some where in the shed
AND this thing which is for the pump up shocks and I may have the diagram for it
Barry
#17 EunUCh
EunUCh
  • 2,774 posts
  • Car:japos
Posted 10 July 2015 - 04:17 PM
I was thinking that the stalk was replaced with UC setup and that the int. function was operated from the stalk....got me wires crossed..my mistake.
#18 _330OLX_
_330OLX_
Posted 10 July 2015 - 04:19 PM
Early Commodore wiper dwell look very similar to the UC units but activate differently to UC, HZ etc.
The Commodore control box is an opaque white colour & is not interchangeable with the UC, HZ control box (the black box in RODOMO's picture)
#19 mandytory
mandytory
  • 101 posts
  • Name:peter
  • Car:lh sedan gpac, uc hatch
Posted 10 July 2015 - 04:29 PM
I fitted a uc intermittent control up to vb commodore switch in my lh years ago and my brother did the same in his lx. Worked well. Can't remember why we did it that way but don't think it worked with uc switch knob.
#20 76lxhatch
  • 7,222 posts
Unless you adjust the wiring to suit of course
#21 mandytory
mandytory
  • 101 posts
  • Name:peter
Posted 10 July 2015 - 04:31 PM
#22 _sunburst73-xu1_
_sunburst73-xu1_
Posted 10 July 2015 - 05:29 PM
Thanks for all the feedback.
I have latched onto an UC switch today and if I get time over the weekend I'll have a crack at fitting it.
#23 EunUCh
EunUCh
  • 2,774 posts
  • Car:japos
Posted 10 July 2015 - 06:18 PM
Just a question about the UC that had the int. wipers fitted , was the int. function a "switched" position on the stalk that enabled the
int. wiper function to work rather than the spring loaded one shot on the others ?...or did they use the same one shot spring loaded switch to trigger some sort of latchable circuit that was then de-latched by doing the same as if to turn the int. on again ?
#24 _sunburst73-xu1_
_sunburst73-xu1_
Posted 10 July 2015 - 07:44 PM
The one I picked up today is a dial and will mount down beside the wiper switch on the lower dash.
It's the same as what Mr Dammitt has posted above.
Edited by sunburst73-xu1, 10 July 2015 - 07:45 PM.
#25 EunUCh
EunUCh
  • 2,774 posts
  • Car:japos
Posted 10 July 2015 - 07:54 PM
^ switch on for int. with adjustable dwell ?
