6 Cylinder running temp and correct thermostat
_LS2 Hatch_
Posted 03 August 2015 - 04:44 PM
I'm sure this would have been covered but I can't find my answers.
Can someone please help me with the following on a Holden 6 cylinder in an LC
What temp should it run at?
What temp thermostat should be in it?
What temp should the hermo fans come on at?
Thanks in advance.
Posted 03 August 2015 - 05:41 PM
Hi Grant operating temp should be around 180-190 deg c and the correct thermostat is 82 c 180f .thats what i have in the LC
thermo fans should be cutting in around 190 as the stat takes another 5-6 odd deg before its open completely.
i had my thermo 12'' fan cutting in at 190 with the std 2 core rad and never had any probs,
cheers Maz
_LS2 Hatch_
Posted 03 August 2015 - 06:29 PM
It's got a 180 thermostat now, and to be honest I have no idea when the fans kick in but I will be checking the sensor.
I have just had the whole car rewired and am slowly sorting out some other small issues.
I had an issue on the weekend that led back to a leaking thermostat housing gasket. Found the two bolts holding it in we're only holding by about three threads and one pulled out.
Now I'm just checking everything to make sure it's correct.
I appreciate the response.
Cheers Grant
Posted 03 August 2015 - 06:38 PM
cheers Maz
WHAT?
You mean Fahrenheit right?
_Muzzy_
Posted 03 August 2015 - 06:43 PM
Those figures are metric
Posted 03 August 2015 - 06:51 PM
Ha ha oops
Posted 03 August 2015 - 07:25 PM
Depends on the combo from what I gather, but those numbers should get you close.
_LS2 Hatch_
Posted 03 August 2015 - 09:22 PM
Posted 03 August 2015 - 10:14 PM
I run a 170f thermostat, but 180f would be fine.
My 202 like the temp around 180-190f. I get worried when temps go above 195f (this doesnt happen often). 180 seems about right TBH.
Posted 04 August 2015 - 02:49 PM
My std 180 runs a bit hot in summer. Up to 210. I fitted a 160, now gets up to 180, but has more power. I use the 180 over winter and the 160 over summer. I made a rubber gasket so don't chew through sheets of gasket paper.
_Macca97_
Posted 05 August 2015 - 07:28 PM
got a 72c or 77c in my 202 with stock radiator and fan, no temp gauge and idiot light gave up awhile ago, never had a problem
