Tachometer wire to coil
13 replies to this topic
#1 _threeblindmice_
_threeblindmice_
Posted 08 September 2015 - 06:32 PM
I Was sorting out the engine bay wiring today and found these two resistors on the distributor / tacho wire , any idea what they would be there for ? do I get rid of them ?
Attached File  172 (2).JPG   119.29K   4 downloads
#2 _threeblindmice_
_threeblindmice_
Posted 08 September 2015 - 06:39 PM
This is on a GMH , LC GTR dash
#3 S pack
  • 15,759 posts
Posted 08 September 2015 - 06:58 PM
They are not original and should not be necessary with an original GTR Tachometer and original points distributor.
Could the car have been fitted with an electronic ignition system that made it necessary to have those resistors to make the tacho work properly???
Edited by S pack, 08 September 2015 - 07:01 PM.
#4 _Macca97_
_Macca97_
Posted 08 September 2015 - 07:40 PM
id say your right there dave
#5 _threeblindmice_
_threeblindmice_
Posted 08 September 2015 - 07:43 PM
It hasn't been on the road for twenty years , were they fitting them in the 90's ?
#6 rodomo
  • 18,062 posts
Posted 08 September 2015 - 09:53 PM
Maybe a V8 fitted at some stage?
#7 _threeblindmice_
_threeblindmice_
Posted 08 September 2015 - 10:40 PM
I don't think so , the wiring looked like old original 6 cylinder  .
#8 S pack
  • 15,759 posts
Posted 08 September 2015 - 11:47 PM
MSD units were around in the 80's as were the HEI ignitions in the Commodores & WB's. That said I don't think the installation of a HEI from a Blue or Black 6 would have required any resistors be fitted to the GTR tachometer trigger wire.
#9 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 09 September 2015 - 12:49 AM
was just chatting to the sparky upgrading my loom only yesterdy actually on Hei.asked whether im going to run std points
or Hei...told him std but down the track i will change to electronic dissy.so he just put another pink wire through and terminal
all he said was the std points wire is a resistance wire and only gives the coil approx 8 volts which isnt suitable for Hei
Edited by madtoranajzedded, 09 September 2015 - 01:00 AM.
#10 TerrA LX
Posted 09 September 2015 - 07:52 AM
Are they on the positive power feed to the tach or the signal wire from the dizzy?
#11 _threeblindmice_
_threeblindmice_
Posted 09 September 2015 - 01:19 PM
They are on the tacho wire Terry , never seen it before and are not shown on the diagram , a lot of odd things on the car , the windscreen  washer bottle was mounted inside under the ashtray  .
#12 mika03au
mika03au
  • 812 posts
  • Name:Michael
  • Car:LX hatch
Posted 09 September 2015 - 07:33 PM
30+ years of wiring being fiddled with throws up loads of "what were they thinking" moments.
This what was was "suplus" from my hatchback.
Attached File  image.jpg   102.47K   1 downloads
#13 RallyRed
  • 8,209 posts
Posted 10 September 2015 - 07:04 AM
Hi TBM,
Who knows with a 40 y.o. car!..maybe the pink factory resistance wire in the coil circuit had an issue at some time..and this was someones way of trying to fix it??
p.s. thought the resistance wire was in the coil circuit, not the tacho circuit........but ?
p..s from where I have seen you drive the car (from pics) assume it goes just fine....and if the tacho also works fine...I'd be tempted to just leave it mate......unless you are looking for a challenge..lol
Edited by RallyRed, 10 September 2015 - 07:06 AM.
#14 _threeblindmice_
_threeblindmice_
Posted 10 September 2015 - 07:51 PM
It's not on Russet Col , I am going to remove them , could be left overs from an old twin point or capacitor discharge system , who knows . Thanks for all the suggestions , the new motor goes in , in a couple of weeks I'm thinking there should be no problems .
