SBC fuel pumps on Holden 6
9 replies to this topic
#1 Torana 202
Torana 202
  • 23 posts
Posted 02 October 2015 - 01:25 PM
I've noticed the SBC fuel pump leaver has a different shape compared to the Holden red/blue/black motor pumps, has anyone checked the actual contact patch on the pump lever after running the Chev pump?
Just a bit concerned that if the contact patch is not ideal that it might cause the cam eccentric to fail particularly with additional pressures of boost referencing the diaphragm.
#2 Torana 202
Torana 202
  • 23 posts
Posted 03 October 2015 - 01:05 PM
Edit : correct font colour.
I've noticed the SBC fuel pump lever has a different shape compared to the Holden red/blue/black motor pumps, has anyone checked the actual contact patch on the pump lever after running the Chev pump?
Just a bit concerned that if the actual contact patch is not ideal that it might cause the cam eccentric to fail particularly with additional pressures of boost referencing the diaphragm
#3 Ice
  • 15,213 posts
Posted 03 October 2015 - 02:02 PM
I had a chev fuel pump on my 186 LC didnt have any issues at all
#4 Torana 202
Torana 202
  • 23 posts
Posted 06 October 2015 - 02:22 PM
Thanks for confirming that.
On small block Chev's the fuel pump is actuated by a pushrod that makes contact at the end of the pump lever. Was just interested to know where the actual contact point on the pump lever is when driven off the Holden 6 cam. The blue motor pump contact patch starts at about 5mm from the end of the pump lever and goes down approx 12mm.
#5 _Bomber Watson_
Posted 06 October 2015 - 02:29 PM
Will try to remember to get some picks of some different sbc pumps that have been used in sixes tonight.
#6 jd lj
jd lj
  • 2,119 posts
  • Name:James D
  • Car:LJ
Posted 06 October 2015 - 03:14 PM
To be honest I don't see the need for a sbc pump on a street driven red motor.
I've had one previously, but have had no problems with a std pump on the same motor.
Maybe if you are reving to 6800 rpm down the length of conrod straight and have a high fuel demand it may help, but on a street car you'd be lucky to maintain those sort of revs for more than a few seconds and therefore the std pump is adequate from my experience atleast.
#7 _SLY HR_
_SLY HR_
Posted 06 October 2015 - 05:10 PM
I have only used a GOSS factory spec replacement so cannot comment.
But.... If you get the chance bomber. I have read lots of conflicting reports regarding SBC pumps on the mighty holden 6.
#8 _oldjohnno_
_oldjohnno_
Posted 06 October 2015 - 05:39 PM
I agree, they aren't really necessary but they are half the price (or less) than the Holden pumps...
#9 Ice
  • 15,213 posts
Posted 06 October 2015 - 06:50 PM
Bingo
#10 _Bomber Watson_
Posted 06 October 2015 - 08:57 PM
I forgot, and walking down stairs is an effort.
Maybe tomorow...
Trust me though, its fine.
