Seam Sealer
15 replies to this topic
#1 Indy Orange
Indy Orange
  • 2,967 posts
  • Name:Paul
Posted 17 October 2015 - 07:27 PM
Hi all ,what is everyone using for seam sealer ,need a good recommendation close to the original stuff as possible .thanks Paul.
#2 neglectedtorana
neglectedtorana
  • 1,053 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 17 October 2015 - 07:33 PM
I was thinking of not using it for no particular reason, is it only necessary for keeping water out?
I am hoping I have put enough paint on the under body of the car to not need it.
Might rethink my plan and know supercheap stock Septone stock seam sealer
#3 TerrA LX
Posted 17 October 2015 - 07:38 PM
Ah, no, not quite.
Seams have some slight degree of movement in them, if not from body torque then from the heat and cold cycle, so seam sealer has some degree of flexibility to it...
Paint can and will crack, allowing moisture ingestion and propagation.
Stay away from superdear products here if you want longevity.
visit your local paint and panel shop supplier and speak with them over the counter for all your needs.
Edited by TerrA LX, 17 October 2015 - 07:40 PM.
#4 _Bomber Watson_
Posted 17 October 2015 - 07:40 PM
Forget the factory like stuff.
Use a good quality polyurethane sealant like Wurth KD bond + seal, Sika 221, or similar.
Can make it look somewhat factory by running a brush over the bead.
#5 Indy Orange
Indy Orange
  • 2,967 posts
  • Name:Paul
Posted 17 October 2015 - 07:49 PM
Have used Tiger brand and not real happy with it ,it's almost like black silicone .wasn't the factory stuff almost like windscreen sealer ? with lots of flexibility and stayed soft?
#6 Indy Orange
Indy Orange
  • 2,967 posts
  • Name:Paul
Posted 17 October 2015 - 07:51 PM
Can you paint over Sika 221.
#7 _Bomber Watson_
Posted 17 October 2015 - 08:24 PM
Yes, you can paint over any Polyurethane adhesive/sealant.
#8 neglectedtorana
neglectedtorana
  • 1,053 posts
  • Name:Tom
Posted 17 October 2015 - 09:11 PM
What about a Mastik?
#9 _Bomber Watson_
Posted 17 October 2015 - 09:26 PM
Yes you can paint over a mastic.
I dont really like using them as a seam sealer though.
#10 TerrA LX
Posted 18 October 2015 - 12:03 AM
Mastic is a sealer for removable joints, such as where the front guard bolts to the inner.
Think of a stove top or sink that bolts into a bench top, mastic is used to seal the component to the substrate to prevent moisture ingestion and allow removal at a later date.
#11 BIG KEV
BIG KEV
  • 1,218 posts
  • Name:Kevin
Posted 18 October 2015 - 06:31 AM
I used a product called "Heavy Drip-Check Sealer" made by 3M
I don't think I will be using it again as its messy stuff if you want a neat job .....Any tips Bomber
#12 _crumo1_
_crumo1_
Posted 18 October 2015 - 07:56 AM
in our smash repair shop we use terroson sealer it is use by 90% of  manufactures world wide  easy to use and look goods good
#13 _Bomber Watson_
I havnt found any real tips, Cunning Stunt of a stuff to use. Havnt used that particular one but have used similar.
Running some masking tape on each side of the seam and thinning a bit at a time on the lid with gp thinners seems to help, bit way easyer to squeeze so.e polyurethane out of a tube and run a brush over it.
#14 tuxedoss
tuxedoss
  • 1,027 posts
  • Car:ss
Posted 18 October 2015 - 09:52 AM
From what I've seen they used 2 different types in the factory, one is used in the engine bay and other areas where it was painted over, its a white colour and looks to be similar to the sika stuff. The other is used all inside and is that black stuff that is like a mastic but not sure if it is, it was laid on real thick. I don't think many use the black stuff anymore.
#15 _Bomber Watson_
Posted 18 October 2015 - 03:24 PM
Factory painted over seam sealer is definitely not a polyurethane.
I think its a hardening mastic but not totally sure. As opposed to the non hardening mastic used elsewhere.
#16 TerrA LX
Posted 21 October 2015 - 06:19 PM
Trade name was drip check BITD
