Autometer sport comp fuel gauge- standard sender?
4 replies to this topic
#1 orangeLJ
Posted 21 November 2015 - 07:59 PM
Fitting an autometer sport comp fuel level gauge to my LJ.
Standar s fuel tank and sender.
Guage when wired up goes well off the scale, so assuming the sender is of a varied resistance that is not compatible with the gauge.
So has anyone had a solution?
#2 LXCHEV
LXCHEV
  • 3,645 posts
  • Car:'76 LX - 383 Chev
Posted 21 November 2015 - 09:11 PM
All depends on the ohms (resistance). There's a variety of gauges, sounds like you have the wrong one.
#3 orangeLJ
Posted 21 November 2015 - 09:22 PM
Yeah, was a second hand lot of gauges, so didnt get a choice in that.
Wondering if I can sort it, worst case, no fuel gauge, but that said, the old one barely worked either, so no big change haha
Is there anyway to tell which resistance I have? I havent been able to find anything online that identifies them
#4 ls2lxhatch
  • 5,335 posts
Posted 21 November 2015 - 11:37 PM
A fuel gauge interface module can be used to match a gauge to a sender.
http://www.speedwaym...dule,66534.html
#5 VDO
VDO
  • 191 posts
  • Name:Chris Curtis
Posted 22 November 2015 - 04:38 PM
The LJ fuel sender can be modified to comply with the ohms range that the gauge requires.
Firstly the gauge will need to be bench simulated to establish it's ohms range.
Then the sender's output resistance range can be modified to suit the gauge.
Alternatively, your original gauge and sender can be repaired to function correctly.
If you need help with this, PM me.
Edited by VDO, 22 November 2015 - 04:41 PM.
