After a nearly 5 year layoff due to a number of reasons including a dance with the Big C I went out to play with the Torana.
I started revamping some of the wiring, but then to my horror I opened up the drivers door to find a big hole just below the top hinge in the A pillar where some thing had eaten through the steel and it wasnt a mouse!!!!
RUST!!!
Bloody Hell.!!!
So after work today started in on the repair.
The door hinge pins came out easier than I though that they would. A hit with a long brass drift so that I wouldn't mushroom the bottom and then supported the door on the trolley jack with a large block of wood to take the load. After the pins were loosened I used a long punch and then an even longer stuffed screwdriver to knock them out.
I marked it out and then cut out what needs to be replaced with a metal balde on my Fein Multitool. A lot more gentle than a grinder and metal blade and no sparks to burn other painted parts. Wasn't as bad as i thought behing the bubbled rust areas. .
Water has gottten in behind the panel on the door hinge and just rotted it away from the inside. The Hinge is still as solid as a rock
So now to get some steel plate and weld in the new bits and then grind the welds flat, prime, paint and no one will ever know.
The just have to work out why the wipers dont want to play the game. I'll check the fuses first before I go diving under the dashboard again. They are a nightmare under there.
Edited by piquet, 15 December 2015 - 07:55 PM.
