4l60e behind 304
13 replies to this topic
#1 _LX355SLR_
_LX355SLR_
Posted 20 December 2015 - 02:33 PM
Had a box built and the builder has used a later core with bellhousing to suit the LS motor. I can't get hold of him as he has shut down for the year and I'm trying to figure out if I can use this box. I bought another box to suit a a 304 with the intention of swapping the bell housing but the input shafts are different length and so therefore the bellhousing lengths are different current bellhousing is 20-25mm longer.
The current housing bolts up but has the starter motor allowance on the drivers side.
Can you get a starter motor to bolt to the drivers side to use the current setup
Or I cut get a section cut from the drivers side of the housing and welded in the passengers side the fit the starter in the original location.
Or any other ideas.
#2 _Gunmetal LH_
_Gunmetal LH_
Posted 20 December 2015 - 08:37 PM
My 2c- a lot of dicking around.
I would wait for your trans bloke (or find another one) and get him to swap over the bell housings and input shafts.  Then you'll have no question about stuff lining up and meshing properly.
Would give you a tiny bit more room in the trans tunnel area with the trans not 20-25mm back.  Got a tailshaft for it yet?  Would suck if you needed to modify it just to get stuff to fit.
There are sandwich plate kits to relocate the starter to the left side of the block but that's a fair bit of cash for something that may not work/fit with the 5L block?
OR...
Found this idea which bolts to the block- no plate.  NZ bloke.  Uses a Toyota starter to get the solenoid at the top and the proper reach.
#3 _LX355SLR_
_LX355SLR_
Posted 20 December 2015 - 09:23 PM
yeah ive also just noticed the converter doesnt sit flush. The locaing nub sits aprox 15mm proud of the mounting bolts. Bloody annoying it will be sitting there for 3 weeks while ive got time off to get things done.
I have a 3" shaft that i will get cut down once its in and i have a measurement.
#4 _Gunmetal LH_
_Gunmetal LH_
Posted 20 December 2015 - 09:27 PM
Bugger.
Surely there is someone who can swap the bits for you before Chrissy?  Good luck.
#5 _LS1 Taxi_
_LS1 Taxi_
Posted 20 December 2015 - 09:55 PM
Call the bloke on his days off and explain his error.
I'm sure for the 1/2 day MAX it'll take to fix it that he'd do it to avoid screwing over a customer.
#6 _LX355SLR_
_LX355SLR_
Posted 20 December 2015 - 10:47 PM
ive tried to call him on friday and saturday but rang out and he is from Victoria and im in WA. Hopefully he calls tomorrow to discuss options but i would say the input shaft bell housing as converter all need to be changed which is a big pain and he will probably want it sent back.
#7 _LX355SLR_
_LX355SLR_
Posted 21 December 2015 - 10:21 PM
Spoke to a builder today and he doesnt seem to think i can fit the 4l60e in my lx sedan. He said the turbo 700's are smaller. Can anyone confirm wether a 4l60e from a VT will fit?
#8 _LS2 Hatch_
_LS2 Hatch_
Posted 22 December 2015 - 05:11 AM
Daz (LS1Taxi) has said in many threads they will fit, just need to massage (hit with a hammer) where the either the linkage or one of the switches locates. A part from that I am confident he says they do fit.
Best wit for him to respond or PM him. If he can give more info he will
#9 _LS1 Taxi_
_LS1 Taxi_
Posted 22 December 2015 - 10:42 AM
Yep. As grant said. Small single hammer tap for the selector shaft and straight in.
#10 _LX355SLR_
_LX355SLR_
Posted 22 December 2015 - 11:27 AM
what about the cooler hoses, any fitment issues as they comeout 90deg rather than on a 45. Or did you put elbow fitting on the case
#11 Holdenbn74
Holdenbn74
  • 151 posts
  • Name:Brendan Nichol
  • Car:LH
Posted 22 December 2015 - 11:43 AM
I'm running a VS 304/Elec auto and fitted fine no massaging required. But running cable B & M shifter.
Sorry LH sedan btw.
#12 _LX355SLR_
_LX355SLR_
Posted 22 December 2015 - 01:13 PM
yeah thats what the gearbox builder suggested. Being the 1 piece case he said it can be built the same intenally but has a smaller overall size and smaller shifter link 25mm vs 75mm i believe. Did you buy a 4 speed shifter or adapt the 3 speed shifter. I currently have a 3 speed quicksilver and bot sure whats incvolved to get the extra click out of it
#13 Holdenbn74
Holdenbn74
  • 151 posts
  • Car:LH
Posted 22 December 2015 - 05:56 PM
Went 4 speed mega shifter mate. Not running a console either. I'm in perth too and cars on the road as of Saturday 👍
#14 _LX355SLR_
_LX355SLR_
Posted 22 December 2015 - 09:12 PM
Lucky bugger. I'm getting dejavu...this time last year I was frantically trying to line al the ducks up to get it back together. Didn't work out for me then either
