LS3 in LC torana?
_Sam88_
Posted 07 January 2016 - 11:55 AM
It's probably a stupid question but does any one know if there is any possible way that I can get a LC licenced in Wa with a 6.2L v8?
I know this exceeds the dpi engine size specifications by quite a bit but I have stumbled across a brand new LS376/525 crate engine and was hoping with enough engineering I could do the mod.
Posted 08 January 2016 - 07:34 PM
Posted 08 January 2016 - 08:19 PM
No frickin chanceHi I'm new to this forum.
Posted 08 January 2016 - 08:20 PM
I was thinking might be poissible with an engineer for ls 4.8 or 5.3l.Assuming you can find one to give you the ok & roads transport will clear it but who knows for certain.
Guys have got all clear for 4.2 & 5.0 holden engines few got 327ci chevs go ahead with engineers.
Good thing if ls iron 4.8 or alloy 5.3 is passed they can be bored out same as 5.7l 346ci ls1 same crank etc or posibly 383 stroker.Just guesswork for now not legwork.
Last option is pay good money for engineered/regoed chev torana already done then rebuild it completely way you want.
Posted 08 January 2016 - 08:21 PM
Like a nice HQ.
Posted 08 January 2016 - 08:25 PM
ThisGrab the engine and find a car to put it in!
Like a nice HQ.
Posted 08 January 2016 - 08:29 PM
You'd want to do a kingy justice LSA would be way to go for a little more money.
Dude on aussiev8s has build thread getting his one engineered
Edited by gtrboyy, 08 January 2016 - 08:30 PM.
Posted 08 January 2016 - 08:35 PM
Not a chance.
Now go slap yourself across the face, then have a good, long, hard look at yourself in the mirror, then go start researching how to build a hot six.
Posted 08 January 2016 - 08:45 PM
I was thinking a coupe, but nothing wrong with a nice HQ Kingswood, or even a Premier.
Posted 08 January 2016 - 08:46 PM
Posted 08 January 2016 - 11:51 PM
pretty sure the NCOP says for LC Torana no bigger than 262 CI dont quote me on that
should be able to get some info off the net or ring DPI
Oh dont worry bout Bomber he,s red 6 brainwashed
Posted 09 January 2016 - 07:00 PM
Some motors can be disguised as a smaller ci, but the smallest of that gen is 5.3 litre?
Good luck Sam.
Posted 09 January 2016 - 08:56 PM
Iron block 4.8 is smallest but apparently easy to mix up a 5.3 & 4.8 untill you pull them apart or just grab junker iron block.
Also some 'aftermarket' iron blocks dont come with engine numbers...
Cranks same just bore them out to make 5.3 or 5.7 or really adventurous can go stroker kit. Ls1/5.7ltr is bore 10 thou then throw away or resleeve gamble.
