brake pipe fittings
6 replies to this topic
#1 rtorana1
rtorana1
  • 249 posts
  • Name:ray
  • Car:lj
Posted 25 January 2016 - 06:00 PM
Can you tell me what size threads the fittings (tube nuts) are on a 6 cyl LJ 1) where the steel brake lines meet the rubber hoses on the front, 2) where the short steel lines screw into the calipers and other end of the rubber hoses,  3) where the steel line screws into the "T" piece at the diff and the wheel cylinders. Not sure but I would imagine them to be all the same size. Can you also confirm that the steel brake line is 3/16" OD.  THANKS.
#2 S pack
  • 15,746 posts
Posted 25 January 2016 - 07:01 PM
Ray
The thread size of the 3/16" flare nuts appears to be 3/8" NPT24. Yes the connections you inquire about are all the same size.
Brake pipes are 3/16" OD bundy tube.
#3 warrenm
warrenm
  • 2,129 posts
  • Car:1972 LJ Torana
Posted 26 January 2016 - 05:57 AM
Ray
Should be 3/8" UNF 24tpi, 3/8"npt is 18tpi.
#4 S pack
  • 15,746 posts
Posted 26 January 2016 - 08:23 AM
Ta Warren
Bloody Supercheap tap & die set is marked incorrectly then.
#5 Dr Terry
Dr Terry
  • 3,337 posts
Posted 27 January 2016 - 01:12 PM
^^^ Correct.
Also it should be mentioned that 3/8"NPT is 0.675" (over 17mm) in diameter.
Dr Terry
#6 rtorana1
rtorana1
  • 249 posts
  • Name:ray
  • Car:lj
Posted 28 January 2016 - 01:59 PM
There are also some larger sized tube nuts, for example at the master cylinder. Can I assume these to be 1/2" x 24 UNF threads?
#7 dattoman
Posted 29 January 2016 - 02:19 AM
One is 1/2 x 20 the other is 9/16 x 18
And the rear brake line into and out of switch block is 7/16 unf
