Opel reverse light switch
7 replies to this topic
#1 Indy Orange
Indy Orange
  • 2,985 posts
  • Name:Paul
Posted 31 January 2016 - 03:04 PM
Hi ,I have a Opel reverse light switch ,it has a arm which is broken but still attached ,just wondering if I can spot weld this without it effecting the internals ,hoping someone can help .thanks.
#2 _hutch_
_hutch_
Posted 31 January 2016 - 03:25 PM
I would clean it up and solder it,but you will need a real soldering iron
#3 Indy Orange
Indy Orange
  • 2,985 posts
  • Name:Paul
Posted 31 January 2016 - 03:42 PM
Not sure if solder would work Philip ,there is resistance on that arm with the bolt in it ,so it must have a spring inside.
#4 Indy Orange
Indy Orange
  • 2,985 posts
  • Name:Paul
Posted 31 January 2016 - 06:37 PM
What's inside these? Is there any plastic?
#5 EunUCh
EunUCh
  • 2,774 posts
  • Car:japos
Posted 31 January 2016 - 07:14 PM
probably some sort of insulation inside and some sort of "seal" on the shaft,i would "uncrimp" the tabs with a "modified" tool and take it apart (carefully) ,but that's what i would do.
the shaft might be retained by something on top inside by who knows what? so just be a bit careful if you decide to take it apart,2 cents worth.
#6 S pack
  • 15,772 posts
Posted 06 February 2016 - 09:47 PM
NOS Opel reverse light switch for sale on ebay
http://www.ebay.com....wAAAOSw5dNWtEl-
#7 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
  • Car:UC S̶u̶n̶b̶i̶r̶d̶ 5000!
Posted 06 February 2016 - 11:09 PM
Submerge switch section in small container of water then weld away...
#8 Indy Orange
Indy Orange
  • 2,985 posts
  • Name:Paul
Posted 06 February 2016 - 11:15 PM
Thanks Dave ,think I'll try and fix the old one ,thanks for that idea Garth.
