Can a 145 or 165/80 fit on a 6 inch wide
21 replies to this topic
#1 _parsons5000_
_parsons5000_
Posted 09 February 2016 - 05:24 PM
As above guys :)
#2 Rockoz
Rockoz
  • 4,043 posts
  • Name:Rob
Posted 09 February 2016 - 07:34 PM
6 inch wide is 150 so cant see why not.
Used to run 185 on the standard rims. Forget whether they were 5 or 5 1/2 inch.
Did go 195 and 205 but they looked a bit stupid
#3 _mello92_
_mello92_
Posted 09 February 2016 - 08:03 PM
Going to be a bit of a stretch.
#4 LHSL
LHSL
  • 995 posts
  • Name:Phillip
Posted 09 February 2016 - 08:31 PM
I have seen 185 on 6 inch. I can't see how a 165 would be safe.
#5 _LS1 Taxi_
_LS1 Taxi_
Posted 09 February 2016 - 08:42 PM
Depends if you want to look like a drifter
#6 LXCHEV
LXCHEV
  • 3,623 posts
  • Car:'76 LX - 383 Chev
Posted 09 February 2016 - 08:45 PM
The 145's on a 6" rim - not a chance. As for the 165's - possibly.
I run the 165/80's on the front of mine, but they're 4" rims. They do have a lot of bulge though. So on a 6" rim they'd be pulled fairly tight. But I reckon they'd fit.
Ask your local tyre shop to confirm.
#7 gtrboyy
gtrboyy
  • 3,216 posts
Posted 09 February 2016 - 09:12 PM
I think my early commo has 185/60/15 on 15x6 rim..looks odd tbh with weird offset rim
#8 _LS1 Taxi_
_LS1 Taxi_
Posted 09 February 2016 - 09:14 PM
I've honestly no idea why the OP doesn't just buy the correct rims. Isn't this the 2nd set of wheels & brakes? Should have figured it out by now?
#9 _LS2 Hatch_
_LS2 Hatch_
Posted 09 February 2016 - 10:02 PM
Cos it's done in threes!!!
Haven't you realized yet?
Com'on Daz, I thought you better than that
#10 _parsons5000_
_parsons5000_
Posted 10 February 2016 - 06:12 AM
ls1 with the rims i have u need a custom offset to fit in the gaurds ,  as u are well aware its a trial and error , springs heights , stub axles , brakes all play a big factor with what does and doesnt fit ,
#11 _mello92_
_mello92_
Posted 10 February 2016 - 12:33 PM
FWIW I was just looking at a 165/70R14 on a 5.5 inch rim and the sidewall was flush with the rim, so on a 6 inch rim it would be a slight stretch.
#12 Heath
  • 18,394 posts
Posted 11 February 2016 - 07:43 AM
You'll get them on if the person at the tyre shop knows what they are doing (an air blaster for the bead may be necessary if they don't know what they're doing), just need to decide if you like the look.
I've got 185's on 7.75" wide wheels on my Datto lol
#13 MARKL
MARKL
  • 94 posts
  • Name:Mark
  • Car:Hatch
Posted 11 February 2016 - 09:24 AM
165 should be OK.
This is the wheel/rim width calculator that I use http://www.carbibles..._bible_pg4.html
There are a number of calculators on the page to help out with all your rim/tyre questions, including an 'ideal rim width calculator'. The calculator says 4.5 - 6 inches for a 165 wide tyre, so you are right at max for that tyre. For the 145 it recommends a max of 5.5.
It also includes calculators for overall diameter etc that are easy to use, takes a lot of the 'trial and error' out of the equation. Hope this helps.
Edited by MARKL, 11 February 2016 - 09:38 AM.
#14 Redslur
Redslur
    Has been Torana owner
  • 3,536 posts
  • Name:Gerry
  • Car:HQ GTS Replica 350.
Posted 11 February 2016 - 11:18 AM
The answer to your question is legally no. A 165/80 can only be placed on 4 - 5.5 inch rims. A 60/65 series can though. Whether you chose to do it is up to you...
#15 rexy
rexy
  • 3,740 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 11 February 2016 - 01:54 PM
Which source is this from Gerry?
#16 _parsons5000_
_parsons5000_
Posted 11 February 2016 - 02:55 PM
I think they came up pretty good
Obviously not sitting on the ground yet but fills the gaurds nicely
#17 Ice
  • 15,207 posts
Posted 11 February 2016 - 05:10 PM
Wow thats skinny should have no probs with heavy steering now
#18 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 11 February 2016 - 11:59 PM
Looks good bud.. whats the dia of the hankook.23'-25'
#19 _parsons5000_
_parsons5000_
Posted 12 February 2016 - 04:46 AM
Total diameter of that on rim is about 645mm
#20 Redslur
Redslur
  • 3,536 posts
  • Name:Gerry
Posted 12 February 2016 - 11:06 AM
Universal Tyre fitment guide. What the ACT RTA uses.
"Rexy
Which source is this from Gerry?"
#21 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
Posted 12 February 2016 - 11:15 AM
Hmm,bigger than i thought,was thinking of getting a pr but a good
couple inches too tall
Thanks for that Ryan
#22 rexy
rexy
  • 3,740 posts
  • Name:Rexy
Posted 12 February 2016 - 07:01 PM
"Rexy
Is this taken from the Australian tyre and rim standards manual?
This is what VicRoads defers to down in Mexico.
