friggen leaking mongrel $@$*&%^&&^$#%^& rocker cover
_hutch_
Posted 27 March 2016 - 07:06 PM
_Muzzy_
Posted 27 March 2016 - 07:13 PM
As the heading suggests I have a leaking rocker cover on my 202,i had one of those aftermarket chrome ones on it for a start,so I turfed that,i now have what I believe is a genuine holden chrome one on it ?? mainly because it has the wire tabs and it has a proper baffle in it,i have tried about 3 different gaskets and what seems to happen is they shrink and leak,the one I have one at the moment had shrunk to the point of I tightened the bolts up by about 1 1/2 turns,i have used the old remedy of putting grease on it to no advantage,apart from using 3 tubes of silicon I'm buggered if I know where to go from here,never had one leak like this,any one had this trouble ??
This could be a long shot, I had a cover rub thru from a rocker just touching it at the end, , it turned out to be a 186 cover on a 173, bridges to rockers re different covers
_hutch_
Posted 27 March 2016 - 07:21 PM
Posted 27 March 2016 - 08:35 PM
Or the bolts are vibrating loose?
Posted 27 March 2016 - 10:55 PM
I use the old aviation form a gasket (permatex no.3) for this sort of stuff and it seals fine with a cork or rubber gasket.
Posted 27 March 2016 - 11:01 PM
Hello Phillip,
I always soak the cork/rubber gasket in water for half hour or so before putting it on,
this allows the gasket to form well before dying out, stays put when taking the cover off again for re-use too.
_LS1 Taxi_
Posted 28 March 2016 - 01:38 PM
Posted 28 March 2016 - 01:51 PM
If you are using wingnuts to secure the rocker cover get rid of them.
Will always get leaks with them.
_hutch_
Posted 28 March 2016 - 05:22 PM
nah don't have them
Posted 28 March 2016 - 07:57 PM
I've had problems with roller rockers smacking baffles or aftermarket rocker covers warping or cracking because of it but never had them leaking using cork gaskets & holden rocker cover bolts with brown gasket goo stuff.
Posted 28 March 2016 - 08:14 PM
I use contact adhesive to glue the gasket to the rocker cover. Tighten then re-tighten after initial warm up.
Soaking them in water is for old school cork gaskets. I don't think you could buy one like that these days. The are usually rubber impregnated.
_NickP_
Posted 06 May 2016 - 03:45 PM
Can I ask how tight should the bolts be? I've just realised mine are loose... no torque wrench
Cheers, Nick
Posted 07 May 2016 - 08:15 PM
Cheers, Nick
Tighten them until they feel right, then do another full turn, which will mean they loosen up, then do another 1/4 turn. Good as gold.
All jokes aside, no torque wrench needed, just nip them with a 1/4 inch ratchet evenly and in star pattern. If it still leaks you have other issues. Its not a cylinder head just a cork gasket.
_big jack_
Posted 07 May 2016 - 08:38 PM
Hello Phillip,
What Dave said.
Posted 08 May 2016 - 06:09 PM
Do what Rob said, contact cement and glue it to the cover, make sure the bolt hole area is not pulled down. Tighten gasket to achieve approximately one third compression of the gasket, if you're real worried use some permatex on the head side of the gasket as well.
